About a week after changing to the rb25 turbo, my clutch hasnt been too happy, for a few reasons. I guess the extra power has worn the clutch, and it had run out of adjustment, which resulted in no fre-play and has effectivly rooted the clutch. Ive found out that the gearbox whine is only the thrust? bearing because of no freplay, but im going to have to buy a new clutch.
Im after a clutch that i dont need to go on steroids to use, but wont need upgrading when i go for my proper turbo/ecu upgrade. What do you guys recommend, and how much would i be looking for the clutch, and how much extra would it cost to install?
Im guessing that the stronger the clutch, the more bighty it gets, so i know i wont get the best of both worlds. Im in brisbane, so where can be recommended up here?
https://www.sau.com.au/forums/topic/21383-clutch-for-250rwkw/
I am going to be honest with you luke,
I have driven a R33 with a twin plate setup, and a R33 with a strong single. (with the same power output as yourself). Personaly i would take the single in this situation for 3 reasons:
1. Cheaper. (for a really good single your looking at around the $700 mark)
2. Doesnt rattle around like a 1986 VL taxi.
3. It will suit your power application perfectly.
if you would like the best of both worlds: (play & grip) i would recommend getting a cushioned ceramic button clutch:
http://www.horsepowerinabox.com/mall/ck06.asp
take a look, they deliver anywhere.
Cheers,
Trev.
Go the twin plate.
I bought a 9 button ceramic-ferride Xtreme clutch when I toasted my stocky. It was ok for a while, but started protesting after about 6 months - this is with only just over 200rwkw.
I then got a twin plate, the clutch I would have got in the first place had I the funds at the time. Much better, and I know it will hold even when/if I do the 3L conversion I have planned (if the RB25 dies).
A single plate clutch that can handle 250 rwkw will be grippy as hell - therefore you will shudder every single time you take off in first, even worse when you are taking off on a hill.
I know this because I have one. Next clutch I get will be twin plate.
matlowth (on this forum) is running a full faced organic single plate clutch. also producing over 300RWKW on a RB30/25. and drives it to work.
proof is in the pudding.
listen if youve got the dosh get the twin, if your scrap for cash grab a good single.
Probably best to buy direct from Japan, will save you some dosh. I got mine 2nd-hand and had it rebuilt:D I had a Nismo 5-puck clutch in my car, only last a few months and was a prick to drive. I'm much happier with the drivability of the twin-plate:D
You get what you pay for. There are single-plate clutches that will handle that sort of power, but they won't be as consistent as a twin-plate. I used an OS Giken twin plate in my R34 with 280-295kW at the wheels. It could handle any kind of abuse and still behave almost like a normal clutch in traffic.
Thanks for the reply.
I just noticed I put the wrong turbo on the post.
I am acutally doing a very similar build with a HKS 3037S so I think thats why I put the wrong one down (edited:)).
Congrats on the time - into the 11s with street tyres awesome!
Also good to see someone sticking with stock internals and making such good power. Seems so many people here dont think it can be done safely, when all they need to do is look to the birthplace of the skyline.
My head gasket and cams arrive on friday:)
Once again welcome to the forums, good to see you here.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
