I recall driving past someplace (maybe Wingfield) that sold cheap (second hand but good tread?) tyres.
I need 2 for some 18" mags I've acquired. Where can I find a place that sells them? Z imports?
https://www.sau.com.au/forums/topic/213838-cheap-18-tyres/
  • Replies 84
I believe it is. How much would you pay, once you have written your car off and are injured in hospital, to go back and buy decent tyres instead of cheapies? A lot, I would guess. I always buy high quality tyres, which have great traction, but more importantly great braking ability. It is the tenths of seconds that matter when you are sliding toward a small child who runs out in front of you.
https://www.sau.com.au/forums/topic/213838-cheap-18-tyres/#findComment-3776615
Hey Ruby. I know the place your talking about. It on Grand Junction Rd. Not Far from Hanson Rd and Grand Junction Intersection.
Its called New and Used Tyre mart. 435 Grand Junction Rd, Wingfield Ph - 8244 4202
Throw up some pics when you have fitted them!
https://www.sau.com.au/forums/topic/213838-cheap-18-tyres/#findComment-3777030
Thanks for that Josh. That rings a bell now.
:blink:
edit: Also started fitting the Ohlins coilovers tonight. Should have them on this week, together with the 18" wheels. Pics to come.
Edited by RubyRS4
https://www.sau.com.au/forums/topic/213838-cheap-18-tyres/#findComment-3777049
Ill check with my old man tomorrow, i got my 235/45/R17's for $110 each, so id say under 150. and i got Wanli's but you can choose.
i payed the same but i got my tyres from bob jane....mates rates...
https://www.sau.com.au/forums/topic/213838-cheap-18-tyres/#findComment-3777595
Alot of crap out there these days. If its for a non performance daily then its not so bad but when I see people throw $90 china specs on there turbo imports.....I try not to drive to close to them..
I think there are a few second hand tyre places around like used tyre mart etc or if you go into a large tyre power they usually will have some out the back. Iam not saying all China tyres are bad but if you are going to purchase them do some research first, Wanli would be the worst out of the lot in my opinion.
Ryan
Edited by ISC-Performance
https://www.sau.com.au/forums/topic/213838-cheap-18-tyres/#findComment-3778071
^^^ I can't agree more Ryan. Having anything less than the GIIIs I have on the back would scare the absolute bejeesus out of me. How people with similar power run the Chinese crap with little grip is beyond me.
https://www.sau.com.au/forums/topic/213838-cheap-18-tyres/#findComment-3778090
Wanli's for me have treated me well so far.....but i can now after about 6 months feel that the grip isnt there.....there is a lot of tread left on the tyre but it just doesnt like griping......thats the bad thing about these tyres i guess....i have run Clears and Nankang on my ride before and Nangkang was really really good.....but the problem is with soft compound tyres they dont last long....
https://www.sau.com.au/forums/topic/213838-cheap-18-tyres/#findComment-3778118
I think being awd you can put a little cheaper on the rear so long as up front you have a little better
i have the MAXXIS Z1 on the front and antyre up the rear i need new rubber on the rear so will probably get the maxxis v1
https://www.sau.com.au/forums/topic/213838-cheap-18-tyres/#findComment-3778203
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
