  • Replies 84
I think being awd you can put a little cheaper on the rear so long as up front you have a little better
i have the MAXXIS Z1 on the front and antyre up the rear i need new rubber on the rear so will probably get the maxxis v1
But awd makes no difference except with accelerating. I don't understand why people think awd is so great. The only thing you improve is traction when accelerating.
Your ability to turn, and stop is exactly the same.
Steve, I was wrong with what I was saying the other day. It was the MZ tyres that wore quickly and gave alot of road noise. It was then the MA tyres I tried next and they were much quieter and lasted a bit longer ... cheaper too.
:P
Going out for rubber now. :whistling:
I've had Nankangs on my last two Skylines. They're what I would call "good value" tyres, sure they're not the best tyres in the world but bang for buck they are bloody good. I'd prefer to pay $200 a corner then $400 a corner for at the most 5% better performance.
Regarding wet performance. The Nankang NSII's that I have now seems MUCH better in the wet then the ones I had 3 years ago. Mabey they've made some changes, because they used to be very average in the wet but now they seem fine?
Edited by Ionos
My clears back in the days gave awesome grip and lasted a shiatload longer then what these elcheapo Wanli's are going.....
Wanli is rock hard rubber/compound = no grip at all. On there only upside this will make them last a loooong time..
Ryan
maybe just go to that place on grand junction and hanson interchange.
I used to go there alot.
got about 4 sets from there.
you can basically walk around teh back and pick which set you want. If you have someone with you they usually pick out crap for you.
i was paying around 80 - 90 for bridgestones with 70 - 80% rubber.
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
