:rofl: Hey guys i am just importing my first jap car and i was wondering what everyoe thinks. Also i would like a big brake upgrade if anyone knows where to get one cheaply.
hope you like the car
NISMO FULL BODY KIT
N1 HEADLIGHTS
TRUST 2.7 LITER
TRUST HIGH CAM SHAFT
HIGH CAMSHAFT INTAKE 272
HIGH EXHAUST CAMSHAFT 280
TRUST RACING VALVE KIT
TRUST ADJUSTABLE SLIDE CAM PULLY
CYLINDER HEAD TUNNING WITH BIG VALVE
TRUST 1.6MM METAL HEAD GASGET
TRUST 87mm FORGED PISTON KIT
TRUST FORGED CONROD
TRSUT FORGED FULL COUNTER CRANK SHAFT
HKS GT 3037 S TWIN TURBO WITH SPECIAL MANIFOLD KIT
SPECIAL RACING TWIN WASTE GATE
TOMEI FUEL DELIVERY SYSTEM
SARD 1000CC INJECTORS X 6
NISMO FUEL REGULATOR
NISMO TWIN FUEL PUMPS
HKS F-CON PRO COMPUTER
HKS EVC
TRUST 3 WAY BIG INTERCOOLER
TRUST 3 WAY ALLOY RADIATOR WITH ELECTRIC FAN
HKS OIL COOLER
HKS TWIN POWER FLOW
SPECIAL ALLOY SUCTION PIPE
OS CROSS GEAR CLOSE RATIO TRANSMISSION
OS TRIPLE PLATE CLUTCH
NISMO LSD
HKS HYPER MAX DRAG ADJUSTABLE SUSPENSION
DRAG TYRES FITTED NOW
APEXI REV/SPEED METER
ALLOY OIL CATCH TANK
GREEDY WATER TEMP METER
GREEDY OIL PRESSURE METER
GREEDY TEMP METER
GREEDY BOOST METER :blink:
https://www.sau.com.au/forums/topic/213841-what-you-think-of-my-r32-gtr/
Yeah talked to Danny its going to cost a little to get it complied. Thats no dramas, the car doesn't get here until the 27th of april, i can't wait. i have already bought a set 18X10 weds to go on it. i want to get a set bride stradia sports seats and bigger brakes. Im thinking grex. Any other ideas on brakes would be good. Also what is a good club in perth to join for track days etc?? :rofl:
Ouch thats a one huge powered car there. You will find it does well at the drags more so than the track. If it's setup right thats a a 9 second car. You need to budget for a motor strip down / basic rebuild if you intend to give it a go at the drags. That sort of power mandates more frequent rebuilds if it's used.
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
