Since u're buying a unit, why not give yourself a favour. Get the prelude. I know they're not fast enough, but should b pretty good for non turbo cars. Also you will save money on insurance and you can use that extra cash for your new house repayment.
Am I making sense this way?
I think low 15s is optimistic at best. Go the wrx out of those two - the prelude is not even in the same league!
honestly, the "I'll get a newer car" theory kind of shits me. Get the best car you can for your money. That definitely doesn't mean get a newer car.
With that budget I'd be looking at either a tight s14a or a very nice r32
rs73, that would be the wisest choice as it would cost me the least to run and would be an ok compromise for a little while. DaiOni, i agree that newer doesn't mean better, but from a financial perspective, the car that will hold the most value in the short term and with the cheapest running costs would probably be more suited to my situation. But then again, a little extra money can often mean a lot more fun :D
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
