hey mate the dump and front pipe you have listed is it to suit a GT30 4 bolt turbine hsg (external gate) or internal? i know your camera is stuffed but could i get some photos of it? what style of high mt manifold were you using?
Buy the way those rims are sweet, if i did not have other things that i have to buy or they had semi slicks on them i would buy them in a flash.
Cheers,
Ryan
  • Replies 65
Posted Images
Strut brace- Cusco
FB GTR Grill - suit gtst s1 + s1.5 (r33)
Dump/front pipe 3" - front pipe is Apexi and dump is custom made by RE Customs
Crossover pipe made by RE Customs
Turbo pipes made by RE Customs - suit top mount
Edited by SLYNE
im not selling a manifold.
the dump/front will sit on any r33 topmount manifold with v band rear
correct me if im wrong anyone. but is it true that even if you buy a brand new dump/front (1 piece) + manifold + turbo it should line up perfect give or take afew mm?
I didnt want to buy your manifold i just wanted to know what brand it was or if you had pics of it so i could get an idea of where your turbo sat. Some manifolds sit the turbo the middle and some at the rear.
All these parts are off a R33 GTST with the std RB25 engine?
Thanks.
worse comes to worse you might have to chop off 1 cm if the manifold that you have makes your turbo sit at the rear or you might not have too.. regardless
yes all parts off GTST R33 engine
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
    • Not required but appreciated. Super Coppermix Twin even the non-competition model feels like the pedal is noticeably heavier than stock which was pretty well judged IMO. I'll be swapping in the Nismo operating cylinder soon to see how that feels.  Personally I haven't felt anything that justifies replacing the damping loop, at least compared to more modern stuff where the clutch delay valve is actually quite noticeable.
    • He made that comment in my thread - In my case the vents ARE to lower engine heat, when the car is not moving, which is the only scenario I have heat problems with the aircon on, sitting in traffic, on 40C+ days. I can't imagine a scenario that this NC needs any at this point in time. I do not know if it will actually make my cooling when the car is MOVING worse, and I sincerely hope that won't be the case. If it does, well, um, f**k.
    • Nice, thanks. Thats why I was asking, there'd been a fair bit of discussion in the E90 world about vents and where it makes sense to put one (ie, over the filters is not great as that is inline or slightly behind the struts and in higher pressure area). I struggle with air flow and pressures. It sill weirds me out that a radiator in the boot can work.
    • Neither really Vents, when located in the right place, will lower the engine bay "pressure", as air has a path to escape, thus lowering the engine bay pressure, thus.....improving the efficiency on the coolant stack (read: IC, condenser, radiator) This is why the Blits vented bonnet on my 33 worked so well, the vent was in the front 1/3 of the bonnet, which put it right after the radiator  If the vents are to far back toward the windscreen, which is a high pressure zone, it can actually force air into the engine bay, causing higher pressure and effectively loosing efficiency on the cooling stack, like the fab of raising the rear of the bonnet, which does allow heat to escape, but only when the car isn't moving  There's heaps of cool "fluid dynamics" info out there, but, I'll attach a video of a 'Merican joint that focuses on "Miatas" as I found it when looking into vents for mine, they explain it way better than me
