hey mate the dump and front pipe you have listed is it to suit a GT30 4 bolt turbine hsg (external gate) or internal? i know your camera is stuffed but could i get some photos of it? what style of high mt manifold were you using?
Buy the way those rims are sweet, if i did not have other things that i have to buy or they had semi slicks on them i would buy them in a flash.
Cheers,
Ryan
  • Replies 65
Posted Images
Strut brace- Cusco
FB GTR Grill - suit gtst s1 + s1.5 (r33)
Dump/front pipe 3" - front pipe is Apexi and dump is custom made by RE Customs
Crossover pipe made by RE Customs
Turbo pipes made by RE Customs - suit top mount
Edited by SLYNE
im not selling a manifold.
the dump/front will sit on any r33 topmount manifold with v band rear
correct me if im wrong anyone. but is it true that even if you buy a brand new dump/front (1 piece) + manifold + turbo it should line up perfect give or take afew mm?
I didnt want to buy your manifold i just wanted to know what brand it was or if you had pics of it so i could get an idea of where your turbo sat. Some manifolds sit the turbo the middle and some at the rear.
All these parts are off a R33 GTST with the std RB25 engine?
Thanks.
worse comes to worse you might have to chop off 1 cm if the manifold that you have makes your turbo sit at the rear or you might not have too.. regardless
yes all parts off GTST R33 engine
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
