hi all ive been doing a fair bit off research on forged pistons but can not make my mind up on size.?
A: Should i go for standard forged size for rb25det,.?
OR
B: Get 20thou oversize forged pistons,.?
option A sounds easy thats if the bores are ok.
But then i can get it bored out the same size as the oversize pistons then i will have a nice smooth bore.?
if you can give me some advice that would be great.
Cheers
Allan.M
https://www.sau.com.au/forums/topic/213876-acl-forged-pistons/
well the motor with standard pistons and rods is fine has not been boosted more than 8psi since i have had it so you think go with the standard size forged pistons then get my machinist to check out the bore then he will let me know if i need more clearance encase of scrubbing from the piston.
but wouldn't it be better to go that tad little bit bigger so there is a fresh new bore to work with.?
cheers
Allan.M
Now i need a rb25det block anyone got one in Adelaide.?
take my time and build it right.
yeah true so do you think its still worth going the 20tho oversize pistons or stick to standard size.?
any advice will help me with this decision.
cheers
Allan.M
Edited by R334door(s2)
get bores checked for roundness. if they are still perfectly round (which isnt uncommon) then stick with std size. but u will still need to get the bores machined out to suit the new forged pistons (even if its just .001 thou)
the bores on my rb26 where still showing the factory cross hatching. perfect round and no machining nessacary for a standard sized set of forged pistons.
well the front 5 where. number 6 had a broken ring land and ever so slight scoring because of it. a slight hone might have gotten ridden of the mark but decided not to take the chance.
Its not so much the roundness, its the taper, as 99% bore wear occurs in the top 15mm. Anyone who has rehoned a second hand bore can tell you that its obvioius as the hone does the whole bore except the top 15mm. IMO if you are having to buy another block, then machine it out, its really not a lot of extra $$$, in the unlikely event that in the future you need to bore it out again twice, then buy another block then.
Edited by Adriano
just get the machinist to check the block first, then get the smallest pistons you can to allow for future use.
no point buying 20 thou over pistons and then finding out you needed 40 thou oversize due to some problem
ok so ive decided to go standard size by what every one has said.I am looking at a block that a friend has and ill get it checked out to make certain the bore is all fine.
cheers guys keep the info coming.
cheers
Allan.M
