Make:Nissan
Model:Skyline r33 series 2
Milage:99,000kms
Transmission:5spd
Colour:silver
Complied yes
RWC supplied yes
Currently registered yes
Price:$15500
Contact: [email protected] or private message
Comments :
Decided that I really want an r34 GTR so I'm putting my 33 on the market to see what interest I get in the car . Few details as follows
Nissan skyline 1996 sII 5spd
Nissan 17inch 350z wheels with good rubber
11months rego
Slightly lowered (maybe king springs)
Strong rb25
Garrett 35/40 turbo on custom manifold
External gate with screamer pipe
Apexi PFC + hand controller
Bosch 044 fuel pump
Sard Adj reg
Bigger injectors
Hybrid FMIC
z32 AFM
3inch exhuast
Turbosmart E-boost EBC
Should be a few things I've left out . Body and paint is very good few marks here and there but better then most I've seen . Interior is excellent seats are good no tears airbag wheel isn't worn still has original dash . Have dyno print out for 282rwkw @18psi on a dyno log dyno which is pretty conservative probably go 300rwkw on dyno dynamics . Has had all fluids changed and the timing belt is new .
The car drives excellent and is good fun sounds nice and doesn't attract too much of the wrong attention . I'm not really fussed if I don't get any interest in the car as I will just keep it and enjoy it some more . Few pictures below
Asking $15500
https://www.sau.com.au/forums/topic/213894-fs-nissan-skyline-r33-s2-282rwkw/
you do realised that catch can is catching nothing... it needs to be either vented or plumbed back into the intake in order for fumes to flow through once the throttle is opened. On idle the RHS of the rocker cover is flowing into the can and back out into the LHS then back into the plenum.
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
