cars getting re-tuned next thursday, but the tuners dont do general servicing... i need a
oil and filter change
spark plugs
and possible fuel filter change
where can i go to get this done, preferably somewhere with skyline knowledge as i normally take it to the local garage but this is the first service on the new engine and if theres anything wrong with it i need them to pick it p
thanks!
adam
https://www.sau.com.au/forums/topic/2139-urgent-servicing/
Do it ureself man its easy as, not like u have a 1jz there:rolleyes:
the only "big" problem is pulling off that crossover thingy off to get to the plugs.
Plus it gives u a warm fuzzy knowing u did it ureself:D
Oh yeah and if ure engine has a fair few ks on it dont use an oil flush. Drain as good as possible after running it for a while and just let it drip for ages. If u use an oil flush it will make the new oil cleaner but it will get rid of the nice gooey protective coating that has built up inside. Then u will probably notice some ticking noises on idle.
https://www.sau.com.au/forums/topic/2139-urgent-servicing/#findComment-39378
Adam32,
I take my Skyline to Per4manz for servicing.... SST don't do any servicing, but Grant certainly does... A little pricey compared to some others, but he does know his stuff. Maybe they are just booked up for servicing...
JHB,
They are not the same company, but they are next to each other. Grant does all his dyno work at SST.
Brett
https://www.sau.com.au/forums/topic/2139-urgent-servicing/#findComment-39645
I dont know about you...
you polly know more about your car than other ppl in a way that how your car should run...
I'll say dont just pop your car in and get just serviced... stay there and watch and learn what they do so later in time you can do the same without $$$ of machanic fee...
now I know a lot more than b4 so I will be trying do it my self on next service...
cheers
Joe :)
ps. Brett guess what? I got new sound and it's AWESOME MB QUARTZ RULES! heheh....
https://www.sau.com.au/forums/topic/2139-urgent-servicing/#findComment-39649
I go to Marows balcatta for my regular warranty service. Cost bout $80. Includes Mobil 1 synthetic oil and filter change, no changing plugs etc. (hey at least not for 100,000kms). Service comes with a warranty too.
Anthony there has one kick arse GTR. Why go to a tuning joint for basic stuff like a service? I'd do mine myself but, I have to for warranty.
https://www.sau.com.au/forums/topic/2139-urgent-servicing/#findComment-40937
Originally posted by Rhino
Those of us who went to the Dyno day last year will remember Anthony and Need4speed........
413Hp at the rear wheels from memory. !!
Yea, I heard that ,yet at motorvation he struggled to get 330 or so and Sumo ( black , techone ) got around 370 at the rears.
Anthony wasn't happy !!
Ken
https://www.sau.com.au/forums/topic/2139-urgent-servicing/#findComment-41137
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
    • I forgot about my shiny new plates!
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
