  • Replies 136
550 (or more) extremely tractable hp, combined with 1590kg and ceramic brakes. Now we're talkin' toocool.gif
The R35 is already a better car than a 997 Turbo fitted with PCCB brakes. Here's the version for people that want to crush even the current model GT2 :cool:
Nissan = Epic win
carbon|ceramic composite rotors- just awesome
that'd be a first for a Jap manufacturer then
Just very expensive, we had to replace a set on the 430GT3 about 6 months ago when a disc cracked. lets just say i could buy a 33GTST or 1 Disc (and they only last 2 race meetings)
comparing power to weight ratio of the limited number of cars thats actually faster, V spec still has the lowest power and highest weight.
looking at Edo 911 GT2 RS and the BMW M3 CLS, they still have better power to weight ratios. the V spec would need around 700ps at 1590kg to have the same ratio as the Edo GT2, imagine how hard it would own then.
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
