hi, can anyone tell me the [correct] offsets for 19.8.5 front,and 19.9.5 rear, for a v35 2003 prem coupe, I would like to keep tyres inside guards, any help on this would be great. Thanks G.T.
The most common offsets for those sizes are +22 front and rear. However if you are lowered and how far will also play a part in how agressive you can go with the offset.
I've also seen front offsets go into the high teens, but by far +22 is the most common.
I'm currently running +24 F and +28 rear on the sizes you mentioned and to they look fine, and i have no rubbing issues at all. The car i slightly lowered with Nismo springs and shocks.
Good time for a pic :D
https://www.sau.com.au/forums/topic/213938-19-inch-wheels/#findComment-3777800
With the right tyre profile you can go lower.
People run 9.5 / 10.5 with +22 offsets for the wheels in the stock guards. If you're running an inch narrower wheels, you can afford to drop 5mm off those offsets and still be safe.
https://www.sau.com.au/forums/topic/213938-19-inch-wheels/#findComment-3778686
Thanks, the wheels Im getting are 19.8.5 F. and 19.9.5 R. offsets for front are 22,30,38,45. The rear offsets are 30,38,45, only. Do you know what the best combo would be. Thanks very much for help. G.T.
https://www.sau.com.au/forums/topic/213938-19-inch-wheels/#findComment-3778813
Good time for a pic :Dv35ixgg5.th.jpg
Thanks nismo, what size tyres are you running, and what is now the ride height from standed now. as per pics thanks G.T. p.s. going to use standed 350z springs for drop,would any year model be OK, Looking for small drop, is it about 15mm not shaw.
https://www.sau.com.au/forums/topic/213938-19-inch-wheels/#findComment-3780495
Hey mate,
Tyres are
F 245/40/19
R 275/35/19
The drop I have is very subtle, probably about the same as what you would get from 350z springs. I lowered my last one on 350z tein H-techs and was very happy with the drop, a bit more than the pic I have but it did scrape on the odd driveway.
However the NISMO package is a massive step forward compared to stock. I've driven a stock coupe around a track, and my current one which as NISMO springs/shocks and sways and it's like night and day.
https://www.sau.com.au/forums/topic/213938-19-inch-wheels/#findComment-3780754
Hey mate,
Tyres are
F 245/40/19
R 275/35/19
Hey nismo, you say you are running 245/40/19 F, is the rolling Dia larger than STD, I thought 245/35/19 would have been the correct size for the front, was there a reason for the larger Dia Tyre, just curious, Thanks mate G.T.
https://www.sau.com.au/forums/topic/213938-19-inch-wheels/#findComment-3783803
Hey mate,
Yep it is slightly larger than standard, but I did a bit of reasearch and the sizes I have (front and rear) work fine together and don't effect teh VCD in any way.
I didn't specifically look for these but when my rims came in from Japan, the tyres were removed. And the guy who brought them in only had these in his workshop and offered them to me at no extra cost. The tyre's are Michelin Pilot Sport PS2 which are around $900 each so i would have been crazy to not take them. :-)
https://www.sau.com.au/forums/topic/213938-19-inch-wheels/#findComment-3787087
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
