Hi all,
I've got a stuffed gearbox in my GTR... it currently has an R32 GTR gearbox in it after the last one broke.
I've found a R33 GTR gearbox for sale that I want to buy, but it's without the transfer case.
Questions:
1. Can R32 GTR transfer be used with an R33 GTR box?
2. I'm pretty sure but to check, there's no differences between R33 vspec and non-vspec gearboxes?
Thanks all..!!!
Tommo.
  • 4 weeks later...
^^ would mean you could pull the fuse like a R32 to put it in RWD mode
how much are good 2nd hand R33 gtr box's going for out of interest
wouldnt u also need the R32 atessa ecu???
cozz 33s and 34s can still send torque to the front wheels when the fuse is out.
but if just changing the transfer case is enough then that would be super
yeah i was never 100 percent sure why the R33 and 34 couldn't just pull the fuse i had assumed it was something internal to the transfer case :P if its the attesa ecu then that would mean turning your R33\34 into a burnout monster would be easier than thought
my research into TCS's havnt even told me if on the R33 you can electronically keep the torque to the rears
>>TCS<<
yeah i was never 100 percent sure why the R33 and 34 couldn't just pull the fuse i had assumed it was something internal to the transfer case :) if its the attesa ecu then that would mean turning your R33\34 into a burnout monster would be easier than thought
>>TCS<<
I believe the R33/R34 transfer cases are always have some power going to the front wheels, I think its called "preloading" the system, its like 5% or a small figure....R32's didn't have this preload from what I've read (not an expert so I'm not 100% sure).
But that part is different to an R32 so I don't know how the R32 GTR transfer case will work.
Hi all,
Questions:
Thanks all..!!!
Tommo.
boxes are the same. Bellhousing is the only diff push and pull type.... easily swapped in 15mins.
R32 and R33 transfers bolt on to both models... R34 does not (getrag has differrent output shaft)
  • 1 year later...
They are not identical. They will do the 4WD/shaft side of things no worries but no speedo readout. I have both cars and they are the same EXCEPT for the internal speedo drive gears and sensor. You can use a R32 in a R33 if you don't care about your speedo not working and vice versa. R32 is mechanical, R33 is electronic. Different size gears on pickups and internal case gears too so you can just swap pickup sensors either. You need R33 transfer in a 33 and an R32 in a 32 for speedo to work. Found out the hard way with this trying to fit a R32 transfer to my 33.
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
    • Remember reading about this not too long ago. been for sale for a long time  this is like when the wife says you need to sell the car so you put it up for a ridiculous price no one will pay
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
