  • Replies 235
i hate any car where the driver does the following:
-turns left from the right lane
-turns into a driveway by veering 2m out first
-drives in the "middle" lane on a 2 lane road
-drives with their high beams and/or fog lights on (unless theres fog)
-speeds up when they know ur going to get past them to get away from the slow useless pricks they are only to slow right back down again when you cant get in because uve caught up to the other slow flamin mongrel in ur lane
-doesnt indicate when turning or changing lanes
-tailgates
these are all road rage offences and generally incur a 20c or 50c coin toll into any panel of the offending car, of my choice.
-tailgates
it becomes road rage if
1. they dont appoligise for there bad driving, an nealy cause an accident
2.if you dont except there appoligy and mouth off insteed..
i hate cars/drivers on the road who dont accept an appoligy if i do one of the above mentioned, you can
judge what the drivers are like and i love when they show me there an impaitent driver or a road rager,
lifted 4x4 on huge chunky mud tyres usually puts uz f*kers back in ur place when i swerve in front of ya to remind you, size does matter, an being a hero in a skyline wont mean shit when ur bonnet is under one of my tyres at the next set of traffic lights..
theres another one... women in 4x4s... a recipe for disaster.
I'm gonna start a "Holden with a Chev badge - Wanker!" group on Facebook ;)
they have the chev badges purely for the fact that it's an 'LS' chev powered car...
unless some knob put's one on anything earlier than a vt.. and also except for the wankers who actually don't know who builds the engines on commonwhores.
I can see numerous posts on lancers with evo body kits. Whats the difference between that and standard GTS-t with a GTR body kit?
Or do we remain silent because we've all done it before ;)
Edited by allblitz
A standard GTST in most senses is a hell of a lot closer to a GTR both parts, looks and performance wise than a Lancer is compared to LanEvo.
Thats just my thought.
And if you find anyone putting a GTR badge on a gtst, trust me, they'll get laughed at too.
You'd have to live under a rock to not to know the LS1's came from the yanks but FFS, it's a Holden. It doesn't make your car "unique" or cool it just makes you look like a wanker. It’s like a GTR badge on a GTS-T or a Syline bade on a VL or a Merc badge on a Crossfire....the list go's on and on..
Or do we remain silent because we've all done it before :domokun:
Ah man I hate that, so shit! :)
Oh gee... better log out now! :P
old VS commodores with newer VX/VT bodykids that make them look like transformers
Ha! And the call us ricers...
Saw a Calais with a Clubsport sideskirt. The idiot left the badges on, ppfftttt :P
You'd have to live under a rock to not to know the LS1's came from the yanks but FFS, it's a Holden. It doesn't make your car "unique" or cool it just makes you look like a wanker. It's like a GTR badge on a GTS-T or a Syline bade on a VL or a Merc badge on a Crossfire....the list go's on and on..
I see where you are coming from, but hope its ok to put a Silvia badge on and remove the 200SX badge on the S15...
Then again I can just import a Silvia... Hehe!! ;)
Edited by (00)SKYLINE(00)
Lol..i dont mind that..
however..
*rubs his 200SX badge*
i wouldnt put a silvia badge on..because i cbf'd
the only reason i'd put a lightning bolt S on the front is that'd it'd be easier to clean around..hah
^^ HAHA!! End of the day, same car as we all know.
The "S" badge looks better then the Nissan IMO
The Silvia Badge look nicer aswell. Make it Jap Spec.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
