  • Replies 247
Well, there is some undercover if you're really up for it.....
we'll have to see in a few hours.
The rain stops, then starts.. then stops again...
so i dunno at this stage... as far as i know... im still up for it LOL
just wondering, is this an actual cruise? or just a meet up?
if its a cruise, where are we heading to?
greet, meet and EATS!! lol
ill still be there!
i wanna wash my car but it might rain....again
Edited by 5hu7o
:down: Thanks for making the effort to come out guys...
despite the weather conditions AND it being double demerits and all.
Wouldve planned for a cruise but yeah, you know.... the rain and stuff...
highway patrol and stuff... next time, it'll be a meet up then a small cruise.
But nice little meet up :)
Nice meeting you all! Once again THANKS GUYS.
yeah +1 with Anna.
very good meet guys, very good to meet all of you...thomas, romeo, jenny, anna, roland, niel...the list goes on.
lol i got my mocha latte so im happy :down: oh and LOL @ [2IMPRS]
will post up my pics soon...
thomas has some too!
about a dozen cars or so... it was an alright turn out considering the crappy weather. Even Moei turned up in the GTR lol
so did albert and a few others showed up as well. Shame i didnt organise a cruise though, weather too crappy.
we were parked near the highway at first... then moved across to the undercover area infront of the domayne.
how many people turned up? I certainly came there and saw no one.. just 1 white R34 with Impuls at KK with P plates and that was it.
hey johnnilicte,
sorry you missed out.. next time if you're early wait around for an extra 5 - 10 mins guarranteed people would start to show up.. it said around 8:30ish .. but there's always a next time..
It was nice to meet new people! Pretty good meet for such sucky weather.. we should sit down and eat next time! :D
Nice to finally meet Anna =) and you're little man is just so adorable!
Edited by missusR34GT
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
