Item: HDi Intercooler Kit
Age: 3~4 weeks used on my car
Condition: Lightly used on near stock car that has seen very few km's since installed
Price: $350 + postage if needed *FIRM*
To Fit: maybe 32 but definitely 33 and 34
Comments: item is in great condition ... why spend 600+ for one of these when you can have it for next to nothing barely used at all!!! Also has had vacuum nipple threaded for boost controller ...
Item: A'pexi Power Intake
Age: 3~4 weeks
Condition: As new
Price: SOLD
To Fit: RB25 equipped cars
Comments:
Item: Custom Aluminum Heat Sheild
Age: On car 3~4 weeks
Condition: Great
Price: $20 SOLD
To Fit: R33 GTS-t with standard cooler piping
Comments: It can be modified by simply covering the extra IC pipe opening by placing a piece of aluminium as I did over the hole ... works a treat because you can duct cold air up to the pod through the factory hole if you have an over top FMIC kit like the one above ^^
Contact: Post a reply in the thread and I'll send you a PM
Edited by BLK33T
Dude, you stil keen to part with the heat sheild??
im keen for it
ive PM'd you my number
Age: 3~4 weeks
Condition: As new
Price: $40 + postage approx $10
Comments:
Condition: Great
Price: $20
FMIC is GT spec tube and fin >> it is 300x600x76mm >> it comes with brackets and has all the genuine joiners and hose clamps needed to complete the installation
Here is the website HDi
Hope this helps
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
