Nissan R33, GTS NA 1998, running very nicely, after 15 laps, power loss and no response from throttle and behaves as if fuel starvation. fuel pump sounds as if running full capacity (screaming) and will not rev over 2000RPM. Have to turn off and restart to get to pits.
If car is allowed to cool down for half an hour, can get one full lap with full power then fault recurs
fuel pump is an uprated wallbro, new fuel lines, filter, tank full.
No fault codes pop up, no over heating, car runs fine and very strong
https://www.sau.com.au/forums/topic/213992-cut-off-at-15-laps-on-track-days/
Sounds like it is going into limp home mode. Walbros tend to get loud when the voltage isn't as great as it should be, however if the battery or alternator was at fault, I would expect it to cause problems at other times too. Did you earth the Walbro to the body, or are you relying on the factory earth?
No I haven't earthed the wolbro to the body, just did all the connections and dropped it into the tank. should that be a problem? trying to look at the manual to check ur point.
I found this is the manual, but it doesn't elaborate. file attached. another member on another post had this to say:
"sounds like you'll need a surge tank.
not really a common issue - but it does happen. i have no problems without one and i would think that i hold more sideways Gs than most people.
15 laps is a fair bit though, i would hazard a guess that the tank would be no where near full."
another friend of mine asked to check the fuel return line as that may be blocked, therefore making the pump run lean
skyline.doc
fuel pump wiring topic here:
http://www.nissansilvia.com/forums/index.p...howtopic=150876
I am not familiar with Skylines, so not sure if all the issues that are in there are applicable, but you may be able to get some benefit from the topic.
Edited by Thunderbolt
Thanks for that. All topics on the forum are leading to the Air Flow Meter. The symptoms the car has look like an AFM problem. Spoke to the garage here and he said the car runs ok after switching on and off again because the computer erases the memory reading, which explains why the car takes me to the pit after switching off and on again. If it was fuel related, the problem might remain constant.
Another thing is that the standard fuel pump did the same thing. When I upgraded to a walbro the problem persisted. Will install my friend's AFM and see how it does. If problem persists I will look at the return fuel lines etc.
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
