hey
when i did an oil change today
i thought id notice where the oil pressure guage sat on the dash
i remember before it was over a qtr
cause it gos 0 qtr 4 qtr 8
after i dumped the oil
i started it up and it went to 4
once it got warm tho it sat at qtr for goin full on
and just above 0 when idle
i turned off the car after goin to my gf's then we went out 30 mins later
and it sat between qtr and 4 the whole time (not driving hard)
and its like that now
the oil i used before was pennzoil gt semi synth 10-40 and it would of had mixed in some valvoline xld 20-50 shit that the stupid mechanics put in before i got my car (he said ooh its turbo rated its fine we cant afford better stuff and they do all this yards cars once imported)
when i did the first change i noticed it idled way better and ran smoother
with this new batch of oil its the same but i didnt take notice of the oil pressure till now
the new oil is shell helix eco10 10-30 semi synth
just need some advice thats all :P
https://www.sau.com.au/forums/topic/21400-r32-oil-pressure-guage-should-be-at/
I've been told that the Standard pressure gauge after time..Looses its accuracy...Do wat Timbar32 Did swap it with a Aftermarket One...Thats one gauge i would want to be accurate in my...
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
    • Ah, to clarify if the car has already been tuned and has been modified and you want to go from a oem cat to a 100 cell or decat or vice versa.Are you saying that the car doesn't need to be tuned after a cat change if it's already been tuned?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
