If you run the appropriate fuel all the time, then there may(should) be power to be gained by advancing. However if it pings(for one of many reasons, which you may not hear), then the ecu will go into its low octane map, richening the mixtures and retarding the timing. There is no engine light, and it will stay in this mode until the ecu is reset i believe, there is "power loss and worse fuel economy" especially if you then retard the timing to the original cas position, then you have even more retarded timing and richer mixtures.
Edited by Adriano
ok have been having a few problems, my c.a.s has problems with the tps switch unpluged if i set the timming say 15 degreees btdc then turn the car off and back on still with tps unpluged it will say timing is around 30degrees btdc and rev alot higher its wierd its as if the car flicking inbetween modes when i turn it on and off but will only do this with t.p.s unpluged and yes i did reset ecu before checking the timing because i had played with it does anyone no what happening
at to you guys, if you have a series 2 motor (might be applicable to series 1 aswell) you must use a short ignition lead from the coil pack to the spark plug. put the timing light sensor around that and then you'll get and accurate reading...
bump anyone have any idea...
bump i have also found when i tightn the bolts up on the c.a.s timing wil drop by 5 degrees example i set c.a.s to 15 degrees btdc then tightn the botlts up being sure not to knock the c.a.s and the timing will be down to 10 degrees btdc is this normal
Edited by rich flavour
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
