mate Enzed etc is your friend. i used teflon braided -4 lines with plenty of heat unsulation and 200 series fittings, but only because mine is an RB30 block and the stock lines don't work well. stick with the hard lines if you can, less stuffing around, $ and no problems with heat in the long run. i would've if i could've.
Most people stick with factory lines as they are by FAR the best for the purpose.
Its going to be $$$ and a pain to get fittings down there when there is factory stuff that bolts on and can resist the heat
is that -4 for both oil and water?
from the ones i've seen its been -4 oil and -6 water :down:
braided lines rock, ive got a braided line to my turbo, and my water lines have been chopped, expanded and had hoses clamped to them. as long as theyre properly insulated theyre great.
mine have made pulling the turbo out a 45min job and installing a 1hr job. the worst thing EVER is trying to get the standard water and oil lines to line up when going back on.
take it to pirtek and ask them for the lengths you need, and the fittings (i reccomend just going from the banjos if possible). then take the fittings and hose home and dummy fit to get the angles you need on the banjos, then mark them or tape them up. go back to pirtek and get them swaged on and your done. saves swivel joints and removes one more thing to go wrong.
also, be aware that while pirtek guys are really switched on, they may or may not have heard of earl's fittings etc, which is why its easier to go from the banjo.
cost a bit but you will never have a problem again.
Dam thats nice TO NICE im jealous good work though
I dont know of too many things i do in 1/2 measures...its either boots and all...or not at all.
check full feature of the car in this months HPI magazine and im sure you will agree.
  • 3 months later...
http://cgi.ebay.com.au/Nissan-Skyline-GTR-...VQQcmdZViewItem
saw these two in another thread. but couldn't find it again....
is this an alright price for all the lines?? just over 300 i suspect.
