Me and some mates are headin down to run that night and thought I would just mention it incase some other guys were thinking of coming but didn't know if anyone else was, FMIC is on, D/S controller is in, fuel pump will be in with tuning on friday. then I will be ready to hit the creek and get less than a 15sec pass hopefully :P:D
https://www.sau.com.au/forums/topic/21404-ec-street-meet-1382003/
Now now... I went looking at helmets yesterday. They wanted from $145 thru to $850 sheesh. So i'll get 1 of those sometime soon and then i just gotta check about my tyre pressure (nitrogen filled so i dont wanna pay $10 every 2nd wed to get em filled back up again).
Bob Jane T-Marts just over near the railway station (behind Strathfield Car Radios) and I think it cost me $4-5ea tyre.
Damnit I shoulda bought MFX's gold rims when I had the chance, now I need to find a really cheap arse set of rims that are 255-266 for drag/track.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
