Just noticed there's a RB20 (I gather RB24) in the Top RB20 Club making similar power figure
(367rwkw) with cams + HKS TO4ZR turbo at 23psi (post #1602) -
http://www.skylinesaustralia.com/forums/To...&start=1600
Edited by SKYPER
  • Replies 50
Im interested to know what sized rear housing and wheel is on the rear of a t04z, surely its not 1.6 like a few t04z's. We recently experimented with a mates RB20 with forgies and all sorts and made 291rwkw on 16psi with a gt3540 with a 1.06 rear. However out boost curve is identical to the power curve and never levels out...LOL! however this 20 made 30psi quickly and leveled out. Any insite jeff as to what could cause such a gradual boost curve? Got cams n all.
Edited by Ryanrb25
Yeah i noticed that too, the extra capacity of the rb24 and big cams really help. You can see how we run much more boost for the same power but i am honestly surprised that a totally stock rb20 head can flow as much as it does with standard cams. The ports and valves are pretty small.
I think it is cool that both these engines are running on remapped standard ecu. :)
Hi Ryan, the turbo is actually a GT4094R - garrett 751470-20
If you are having problems with lazy spooling the things to look for would be exhaust manifold leaks, wastegate leaking, cam timing.
yea thanks jeff, its got a pair of jun cams and cam gears, full rebuild with aries pistons, we tuned it ourselves with a microtech ltx12s, i think its just the nature of the turbo and 20 combination....goes like an animal nonetheless, cheers for your advice. we'll tinker a little bit more.
by the looks of things its around 160km/h so around 3800-4000rpm depending on the ratio. Keeping in mind, depending on what bleeder/controller you are using boost will be a bit flatter if it isn't so high because the actuator will start to open sooner with lower boost. Only slightly tho.
Thats some pretty sik numbers Jeff, (around 500hp) good effort.
That magical 400kw figure doesn't seem too far away with a decent cam profile.
I noticed you've decreased spring travel to increase the rate & seat pressure, as long as there is no chance of binding & room for more lift I can't see why you wouldn't get even more impressive numbers.
We must hook up as discussed a few weeks ago when I get back from QLD, cheers.
PS: As others have already stated here, it sounds like you'll get a better reception here as opposed to ns.com
  • 1 month later...
Sorry to dig up an old thread i was just after some info on the re shimmed stock valve springs if anyone can enlighten me???
I have HKS 264 cams (cant remember the lift) to go into my RB20 and wasn't keen on upgrading the valve springs if i didn't have to :thumbsup:
Just wondering who it was that shimmed them, whats involved and roughly how much it cost???
Cheers Ben
mate seems like turbo tune ain't change much since back in 05/06 they overtuned my engine which almost went bang, before i ripped it out and put a new one in then took it blackwood dyno got a tune from them sudden;y more power better response and it didn't wanna go bang anymore,
then they told me wasn't us it was u!!!
for the 1500 bucks i spent on rb25det including buying and installing and tuning (only 40,000ks on engine) i didn't bother trying to chase it up legally would have cost me to much then
thats my glowing recommendation for turbo tune love ya!!
dude, im not saying your wrong or right etc.... i just want to clarify the rb20 that they have built was a lazy engine that was replaced my a fresh one out of a customers car, which had been laying around, they put it in an s14 shell, used a whole heap of parts laying around and FOR A LAUGH tried to find the limits of the motor, It was over a few beers, a few mates and a few laughs after hours and im pretty sure they intended to blow it up, It was by no means an example of what they'd deliver to a customer in any way...
whats the highest safe amount of boost to run with a stock rb25?
do a search man, i personally wouldn't run any more than 17-18psi which a thicker headgasket.
Ryan... the soloution for chris's car is simple.....
Nitrous. And Lots of it. :blush::D
I am also intending running 1.1 - 1.2 bar with stock head gasket.... not pushing the same power as you though Simon. :thumbsup:
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
