Just noticed there's a RB20 (I gather RB24) in the Top RB20 Club making similar power figure
(367rwkw) with cams + HKS TO4ZR turbo at 23psi (post #1602) -
http://www.skylinesaustralia.com/forums/To...&start=1600
Edited by SKYPER
  • Replies 50
Im interested to know what sized rear housing and wheel is on the rear of a t04z, surely its not 1.6 like a few t04z's. We recently experimented with a mates RB20 with forgies and all sorts and made 291rwkw on 16psi with a gt3540 with a 1.06 rear. However out boost curve is identical to the power curve and never levels out...LOL! however this 20 made 30psi quickly and leveled out. Any insite jeff as to what could cause such a gradual boost curve? Got cams n all.
Edited by Ryanrb25
Yeah i noticed that too, the extra capacity of the rb24 and big cams really help. You can see how we run much more boost for the same power but i am honestly surprised that a totally stock rb20 head can flow as much as it does with standard cams. The ports and valves are pretty small.
I think it is cool that both these engines are running on remapped standard ecu. :)
Hi Ryan, the turbo is actually a GT4094R - garrett 751470-20
If you are having problems with lazy spooling the things to look for would be exhaust manifold leaks, wastegate leaking, cam timing.
yea thanks jeff, its got a pair of jun cams and cam gears, full rebuild with aries pistons, we tuned it ourselves with a microtech ltx12s, i think its just the nature of the turbo and 20 combination....goes like an animal nonetheless, cheers for your advice. we'll tinker a little bit more.
by the looks of things its around 160km/h so around 3800-4000rpm depending on the ratio. Keeping in mind, depending on what bleeder/controller you are using boost will be a bit flatter if it isn't so high because the actuator will start to open sooner with lower boost. Only slightly tho.
Thats some pretty sik numbers Jeff, (around 500hp) good effort.
That magical 400kw figure doesn't seem too far away with a decent cam profile.
I noticed you've decreased spring travel to increase the rate & seat pressure, as long as there is no chance of binding & room for more lift I can't see why you wouldn't get even more impressive numbers.
We must hook up as discussed a few weeks ago when I get back from QLD, cheers.
PS: As others have already stated here, it sounds like you'll get a better reception here as opposed to ns.com
  • 1 month later...
Sorry to dig up an old thread i was just after some info on the re shimmed stock valve springs if anyone can enlighten me???
I have HKS 264 cams (cant remember the lift) to go into my RB20 and wasn't keen on upgrading the valve springs if i didn't have to :thumbsup:
Just wondering who it was that shimmed them, whats involved and roughly how much it cost???
Cheers Ben
mate seems like turbo tune ain't change much since back in 05/06 they overtuned my engine which almost went bang, before i ripped it out and put a new one in then took it blackwood dyno got a tune from them sudden;y more power better response and it didn't wanna go bang anymore,
then they told me wasn't us it was u!!!
for the 1500 bucks i spent on rb25det including buying and installing and tuning (only 40,000ks on engine) i didn't bother trying to chase it up legally would have cost me to much then
thats my glowing recommendation for turbo tune love ya!!
dude, im not saying your wrong or right etc.... i just want to clarify the rb20 that they have built was a lazy engine that was replaced my a fresh one out of a customers car, which had been laying around, they put it in an s14 shell, used a whole heap of parts laying around and FOR A LAUGH tried to find the limits of the motor, It was over a few beers, a few mates and a few laughs after hours and im pretty sure they intended to blow it up, It was by no means an example of what they'd deliver to a customer in any way...
whats the highest safe amount of boost to run with a stock rb25?
do a search man, i personally wouldn't run any more than 17-18psi which a thicker headgasket.
Ryan... the soloution for chris's car is simple.....
Nitrous. And Lots of it. :blush::D
I am also intending running 1.1 - 1.2 bar with stock head gasket.... not pushing the same power as you though Simon. :thumbsup:
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
    • Is it oil smoke or fuel smoke? They smell different.
