  • Replies 50
As SLED said shimming your valve spring will reduce the amount of lift you can achieve before you encounter binding issues. So it will depend on what lift cams you have as to how much you can shim them if you can at all.
dude, im not saying your wrong or right etc.... i just want to clarify the rb20 that they have built was a lazy engine that was replaced my a fresh one out of a customers car, which had been laying around, they put it in an s14 shell, used a whole heap of parts laying around and FOR A LAUGH tried to find the limits of the motor, It was over a few beers, a few mates and a few laughs after hours and im pretty sure they intended to blow it up, It was by no means an example of what they'd deliver to a customer in any way...
do a search man, i personally wouldn't run any more than 17-18psi which a thicker headgasket.
sweet, so 7-10 would be safe with a decent tune then i guess
I realise that but just wondering who shimmed them and to what tolerance, cost involved etc.
Im installing 264/9.0 cams into my RB20 which are direct drop in for clearances but wondering if its worth shimming stock springs, buying upgraded items or just let it be :)
Cheers Ben
QUOTE(jager @ 3 Jun 2008, 04:13 PM)
mate seems like turbo tune ain't change much since back in 05/06 they overtuned my engine which almost went bang, before i ripped it out and put a new one in then took it blackwood dyno got a tune from them sudden;y more power better response and it didn't wanna go bang anymore,
then they told me wasn't us it was u!!!
for the 1500 bucks i spent on rb25det including buying and installing and tuning (only 40,000ks on engine) i didn't bother trying to chase it up legally would have cost me to much then
thats my glowing recommendation for turbo tune love ya!!
i realise that it was for fun, i was just dissapointed how they handled the situation on my vehicle and because of my dissapointment i want to put my 2c in, however if they treated all there customers the way they treated me they wouldn't have a business so obviously i was that one unlucky customer, as stated above, really how am i going to prove it was them not me or vice versa, so i cut my losses and moved on.
however i am intitled to give my opinion on how i was served
and i leave it at that as this isn't a thread about me
Cheers Ben
Ben unless you're planning on revving the thing alot more than it was designed, go with the stock springs. Shimming is never a good idea and is usually a cheap way out of avoiding valve float at extremely high rpm. We used to see boy racers either shim the crap out of their springs and end up breaking overhead gear due to binding or others that would use double & triple springs which would end up pounding weltite inserts deep into alloy head chambers.
If you are seeking extremely high rpm though, you'll also need to think of upgrades on your internals to be able to cope. Stock springs would be fine if you're only going an extra 1000rpm or so.
yea thats fair enough champ, im not defending anyone but turbo tune have been there for many years so they have to be doing something right i suppose.
On the other motor limiter was set at 8850 and probably keep it there with this one as well with the additional parts (cams, injectors, z32 etc) to go in. Other than that its stock as a rock and will stay that way *touch wood* but will be a little stronger than last time eg: can run more boost/timing :happy:
I think i'll just drop the cams in and see how i go from there with the stock springs for now.
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
