ClutchBurndout-:( Posted April 8, 2008 Share Posted April 8, 2008 Not sure if this is the correct spot to post this, so move if nesisary mr.moderator i was on my way home tonight and for watever reason i decided to put my foot down a little harder than average up a slight incline, as i was going as normal i felt the turbo kick in bla bla, but without taking my foot off the slightest it felt like something restricted the power once or twice, like as if a big gust of wind hit the front of the car, but it wasnt windey. So just wondering if anyone else has had this issue themselves, i was thinking maybe i need to get the fuel injectors cleaned or something? im not the sharpest tool int he shed when it comes to "issues" with the car any help is appreaciated P.S. i sore Semi-Pro at the flicks tonight, its piss funny Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/ Share on other sites More sharing options...
Kaz200 Posted April 8, 2008 Share Posted April 8, 2008 like it was cutting out do you mean? Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/#findComment-3779863 Share on other sites More sharing options...
ClutchBurndout-:( Posted April 8, 2008 Author Share Posted April 8, 2008 yea well it wasnt cutting out persey, it was a slight pause in power, there was still push, but it halted once or twice, straight after the first Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/#findComment-3779872 Share on other sites More sharing options...
SXR Posted April 8, 2008 Share Posted April 8, 2008 mod? Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/#findComment-3779877 Share on other sites More sharing options...
_Ryan_ Posted April 8, 2008 Share Posted April 8, 2008 violent cut out? R&R? Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/#findComment-3779878 Share on other sites More sharing options...
Kaz200 Posted April 8, 2008 Share Posted April 8, 2008 well.. I was thinking maybe just dirty/fouled spark plugs, esp if your car is running rich.. but I'm not sure if I'm interpreting you right.. could be a whole bunch of things really. Do you have a Consult cable? Esp if you're not great with mechanical stuff, you could just take your car to Ray/SXR, he will sort it out for you Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/#findComment-3779948 Share on other sites More sharing options...
Kaz200 Posted April 8, 2008 Share Posted April 8, 2008 Also try searching/posting in this forum: http://www.skylinesaustralia.com/forums/Ge...enance-f10.html or the forced induction forum maybe Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/#findComment-3779953 Share on other sites More sharing options...
ClutchBurndout-:( Posted April 8, 2008 Author Share Posted April 8, 2008 na its not violent, its a realy suttle lack of power wene my foot goes down Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/#findComment-3779994 Share on other sites More sharing options...
ClutchBurndout-:( Posted April 8, 2008 Author Share Posted April 8, 2008 ok thanks kaz Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/#findComment-3779995 Share on other sites More sharing options...
BRUNSKIGTST Posted April 8, 2008 Share Posted April 8, 2008 did u hit 180km/h ????? skylines are restricked to 180 unless you had comp remaped and taken off the restricker other wise that what it is maybe Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/#findComment-3780101 Share on other sites More sharing options...
RCHOO Posted April 8, 2008 Share Posted April 8, 2008 did u hit 180km/h ????? skylines are restricked to 180 unless you had comp remaped and taken off the restricker other wise that what it is maybe Dont answer that.... Matthew If it keeps doing weir stuff that you cant workout. Head down and see Ray ( SXR ) at RE Customs. Its better to fine a problem in it early stages. Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/#findComment-3780118 Share on other sites More sharing options...
ClutchBurndout-:( Posted April 8, 2008 Author Share Posted April 8, 2008 Cheers mate, will explore whats going on a bit more then do something about it. restricted to 180kz? ive had mine past that. On that note, did the R33 S1 or S2 have a different diff? because CAJFLY can sit on 100kmph at i think 3.5 revz, and mine sits at 2.5 revz, this standard? or do you think they have installed a different diff or something? chars!!11 Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/#findComment-3780329 Share on other sites More sharing options...
DogKnight Posted April 8, 2008 Share Posted April 8, 2008 My car was originally an auto which was converted to manual before being imported. I dont know how to properly explain it, but the auto diff rotates less per wheel rotation. My car will sit just above 2.5k revs when going 100kmh. Hope that helps (R33 S2 gtst) Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/#findComment-3780434 Share on other sites More sharing options...
CAJFLY Posted April 8, 2008 Share Posted April 8, 2008 mine sits on 2800rpm at 100kmh now, i dunno why it was sitting that hight in the first place but nows its down alot so all is good Link to comment https://www.sau.com.au/forums/topic/214071-restriction-problems/#findComment-3780467 Share on other sites More sharing options...
