Doesnt matter what version you get, they are all the same, been using this site for a while now, has some realy good deals. Just make sure you get no region protection.
If you have a ps3 you dont have to worry about region protection. But yeah play-asia is good!
https://www.sau.com.au/forums/topic/214090-play-asia/#findComment-3783864
PC & PS3 games don't have region locks.
360 & Wii does :D (PAL, NTSC US, NTSC JP)
Theres a lot of 360 games that are region free, like Rainbow 6 Vegas 2, Bioshock, Call of Duty 4 etc...
And for the Wii, you can get the Wii Freeloader that enables games of any region to be played on a PAL console, ive got one and play Super Smash Bros. Brawl, it works a treat.
https://www.sau.com.au/forums/topic/214090-play-asia/#findComment-3792389
I want to get a freeloader to play Brawl but have heard on some forums that Mario Mart might disable the freeloader from working so I think I might hold off till it gets released here. (if it ever does)
https://www.sau.com.au/forums/topic/214090-play-asia/#findComment-3793418
There was also a rumour that the latest Wii update would disable the Freeloader, but ive got the update and nothings happened so far...
https://www.sau.com.au/forums/topic/214090-play-asia/#findComment-3795288
Which version of the Wii do you have?
As far as I know, there are 3 different versions of wii (1st one is from Lah10000000 - Lah10159999, 2nd from Lah10160000 - Lah10215999 & 3rd "newest" is from Lah10216000 onwards).
And from what I have read, the new version, which is the one I have don't support the freeloader, but I could be wrong.
Just went to mod shop & they say it would cost $200 to chip the new wiis >_>"
There goes saving money again...
Edited by Mayuri Krab
https://www.sau.com.au/forums/topic/214090-play-asia/#findComment-3798139
personaly id rather pay the extra 10 or 20 dollers and get the case and manual and all that bollocks, lot more work to save a few dollers... but were all different,
I got my copy of COD4 for $70, and it comes just as it would from k-mart etc for $110-$120 :P
https://www.sau.com.au/forums/topic/214090-play-asia/#findComment-3807204
Yeah its exactly the same... they dont send it to you in a plastic disc sleave... its got the cover and manuel etc...
Infact my Naruto: Rise of a Ninja is the Japanese version, and the manual is all in english, cover is all in english, game is all in english (Shudder)...
https://www.sau.com.au/forums/topic/214090-play-asia/#findComment-3807282
Well i bought mine in Feb (Possibly May?) and its - LAH10364941, and the Freeloader is still running like a charm... and Smash Bros Brawl is still 100% playable.
Well, It appears freeloader does work with the 3rd revision of the wii :down:
I guess its only the mod chips (the 1st gen ones like wiikey) doesn't :laugh:
https://www.sau.com.au/forums/topic/214090-play-asia/#findComment-3807854
ummm i think because the aussie $ can fluctuate depending on the market or whatever, it can possibly change, They correctly convert the US$ amount to the AUS$ amount though... so whatever it says its gonna cost, is whatever you pay, basically...
P.S. im not sure about an AUS bank account... i pay via Visa Debit... works fine for me...
https://www.sau.com.au/forums/topic/214090-play-asia/#findComment-3814007
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
