It could. But needs modifications to coolant galleries. As rb25 and rb20 are different in that matter. Also the inlet ports are different.
It has been done before though. So you can try it. Not a cheap bolt on job like for rb25 though.
Mate the front facing ones on a 20 are really a lot of mucking around. I did one on mine and If i had my time again I definitely wouldnt. If your changing it because you have a top mount turbo just redirect the piping off the standard manifold as ugly as it is.
I know this isnt a greddy one but you get a basic idea
You will need a radiator header tank
vacuum fittings
modify the coolant pipes and also get it lined up so the top radiator hose still fits
throttle cable
throttle cable holder
battery in boot unless your buying a mega small one which is expensive
make sure the coolant lines dont foul on the thermostat housing
redirect a few vac lines and coolant hoses
I also had to change the angle on the flange that bolts to the TB to get it to line up with the battery tray and clear the TPS
after all that this is what it will look like.....and on a 20 with the large throttle body and shorter runners you may lose some response...which you dont really need with an RB20 :down:
Hope that helps you out a bit
Edited by TazzS13
