  • Replies 44
well i threw in the towel today :)
have been in a dead end job for far too long.
gave notice today... and today is my last day :D
i am gonna be starting with Telstra on wednesday
horay for me !!! :D
what did u do before? congrats
If I left my workplace, they'd be screwed. :D
Been here over 8 years from day dot when it all started. I've built the business to what it is today.
Actually, had a meeting with the business partners today and laid a few things on the line. I'm getting a raise soon! :)
Plus, I might be sacking one of my admin staff. :D
Yeh good work fella, So Telstra Hey, One of my best mates is a "team leader" at Telstra, which building are you going to? Pirie st? Know what level you'll be on??
yeah i will be in the pirie st building, think im on the 10th or 11th floor... pretty sure that is where Bigpond is
Good job Carl im sure thats a load off your mind
too right, made my manager cry when i handed her my resignation (not on purpouse... she just burst into tears) bit tough to go tho... made some good friends here
Yeh righto, think my mate is on the 12th or 13th or something.......
I've got friends and family who work (or have worked) for Telstra. They all way the same thing: same bullshit, different workplace! :)
But I'm sure it'll be a fresh start for you with less stress and shit.
:D
:D
oh yeah, i dont doubt it... but at least there will be opportunities bigger n better things there. there is less than fk all room for promotion etc where i was
Yeah, I put up with alot of BS being the manager and all (including from my bosses), but at least I get regular salary promotions that make it all worthwhile. I'm responsible when it goes wrong as well as going right, so the pat on the back is worth it. There's always far more ups than downs.
:D
:D
nice :)
i was responsible for 12 engineers, and only got feedback when the sh*t hit the fan... the culture and work ethic there leaves a bit to be desired. im postive that in other environments all of the guys there would kick ass, unfortunatly they are getting stifled in the current environment.... but meh! this is no longer my concern :P
If I left my workplace, they'd be screwed. :)
Actually, had a meeting with the business partners today and laid a few things on the line. I'm getting a raise soon! :D
Plus, I might be sacking one of my admin staff. :P
There is always someone who can do a job better and for less money.
Everyone is replaceable.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
