One of the first things i bought for rb30det project was the head. I bought a greddy replica intake plenum as i just cant afford the genuine item :(
It arrived and i put aside till i wanted to fit it. I went to bolt it up to the head but the 2 or 3 locating studs dont line up, by a long shot. There a 3 studs, the top front and rear and the third is one in the middle. If i pick one to line up the other either misses the hole or the stud goes into the plenum runner! its as if the plenum is too long for the head. Ive never heard of these plenums not lining up so i have to wonder if the head is actually a rb20 and ive been shafted royally.
Yet the high mount exhaust manifold lines up sweet, but is made for 25 heads only.
Please give me some advice>!!!
https://www.sau.com.au/forums/topic/214188-head-check/
RB20/25 exhaust side is identical, so that would line up regardless of what sort of head you had.
You may very well have a RB20 head, as the inlet manifolds are different and not interchangable..... Easiest way to tell would be check the combustion chamber on the head as RB20 block has a 78mm bore and RB25 is 86mm.
Hope that helps you mate.
https://www.sau.com.au/forums/topic/214188-head-check/#findComment-3782736
Umm measured the combustion diameters, 86mm. My workmate suggested there could be a difference between th s1 and s2 heads. Ive taken some photos but cant upload them jst yet. It also has the oil passage for the vct...
https://www.sau.com.au/forums/topic/214188-head-check/#findComment-3785875
i may be guessing but from memory a RB20 intake will not fit a RB25 head...think you might have a RB20 intake mate but I dont really have a way of proving this.
I just know I went to buy one of these cheapy aftermarket plenums and they only had ones to suit a RB25 so that would suggest the RB20 one is differant
https://www.sau.com.au/forums/topic/214188-head-check/#findComment-3833692
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
