Salesman at motor bike joint tried telling me that Motul 5.1 is a silicon based fluid???????
Now I know Dot 5 is silicon, and quick google search shows that the Motul Dot 5.1 is definitely non-silicon based
Question I have, not sure whether to get the Motul 5.1 or their higher temp RBF600 fluid, I'm upgrading the brakes on my S15 with R33 items new RDA slotted rotors and new TRW Lucas pads, the car has ABS and Motul advertise the 5.1 as ABS specific.
The car see's the track every 1-2 months, mix of drift and club track days depending on what I can fit in with
cheers
https://www.sau.com.au/forums/topic/214209-brake-fluids-motul-51-and-rbf600/
cheers
Why are you using ~600 degree brake fluid with ~300 degree pads?
Cheers
Gary
Cheers
Gary
Hey,
It was recommended to use RBF600 for track days, to avoid the fluid boiling, is there any disadvantage to using it over say Motul dot 5.1?
I'm planning on using some better pads next time but my pads are not rated close to 600 degrees...
Well RBF600 is just rated higher temp than the normal 5.1...
If you're still on street tyres and street pads you shouldn't be boiling any decent DOT4 brake fluid. The Motul 5.1 or RBF600 will be fine as well....
Exactly what swanny180 said.. Same here :D
Except im still using stock nissan pads which bite just as well on track (has been proven both times i have been out there with the quickest time of 1.13 on stockish 33)
Edited by siddr20
Hey,
The issue is that the pads will stop working (fade) long before the brake fluid fails (boils). So spending (waisting) money on ~600 degree brake fluid isn't going to give you any benefit. You might as well save the money and buy some ~300 degree brake fluid this time. Let's face it, you are going to have to change the brake fluid when you put the new (~600 degree) pads in, so you might as well only spend the extra money on the ~600 degree brake fluid when you actually need to.
R32/33/34 Skylines with their 4 spot front/2 spot rear brake callipers have fairly good heat transfer insolation from the pad to the fluid and, as long as you do a cool down lap, new/fresh brake fluid boiling is not an issue. It's when the system gets contaminated by water (brake is hygroscopic) that boiling becomes an issue. We use Castrol Response Super DOT 4 and have never had fluid boiling issues.
Cheers
Gary
Point taken, I was going off advice from this forum from some people who recommended going RBF600 in the fluid.
I'll consider using standard dot 4.1 fluid next fluid change with some decent pads :P
Thanks for the advice.
Just understand that the 600 degrees for the brake fluid is in fahrenheit.
The 300 degrees for the pads is almost certainly celsius.
So the difference is actually only 15.5 degrees (celsius)
Never the less the point still stands. No point having million dollar brake fluid with 10 cent pads, or the other way around even.
i know its a little bit off topic, but i heard the dot 5 or 5.1 not quite sure, can eat away at the rubbers on your brakes system??
Whats the deal with this? is it true?
Yes it is true. Some silicon based fluids are incompatable with the seals found in the braking system.
So Dot 5.1 in my R33 GTS T would be good?
Planning to swap out the brake fluid very soon.
I think the conclusion of the thread was go greater than dot 4 only if your doing a track day with good pads...(and even then, its unlikely to boil...maybe if your running semi slicks and track pads dot 5.1 is definitely a good idea).
Sydneykid, who does race advised that he uses Castrol Dot 4 without any issues at all. which is an interesting opinion, I have never boiled brake fluid so I'm considering going back to Dot 4 and seeing how it goes :)
Does that sound about right?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
