your talking about your timing belt aren't you?
if so it's not the easiest job in the world...
not too say that you cant do it, but how are you going to check the bearings etc? if they snap after the change --- good bye engine! prob best to get a pro to check it all for you!!
https://www.sau.com.au/forums/topic/21421-changing-cam-belt/#findComment-453243
Yup, I'm looking at my engine in pieces, and where the idler bearing bolt has snapped off in the block due to overtightening coz of the FCUKwit who fitted the timing belt. DONT do it yourself if you dont know what your doing, and make sure the mechanic knows what he/she is doing. Timing belts can DESTROY engines if not done properly.
https://www.sau.com.au/forums/topic/21421-changing-cam-belt/#findComment-453295
had a mates car do that recently, ended up being a blown head gasket!! hope that's not the case, does it rev ok up higher, and when warm?
you can check the gasket pretty easy with the norm white stuff under oil filler, white smoke etc, or take it to a mechanic. they have a cool little device that goes on the radiator filler and chances colour when it meets exhaust gas, so no major work to check this!!
hope it isn't this though!
https://www.sau.com.au/forums/topic/21421-changing-cam-belt/#findComment-454343
yeh, i dont think its my head gasket cos theres no white smoke, just a shitload of black smoke, i think its cos the o2 sensor is making it run fat, and burning alot of petrol, and theres no water in my oil, visibly... i hope its not the head gasket, cos thats mucho worko getting to it, ey? having said that i do seem to have an oil leek at the passenger side firewall side..on hte block a bit...
https://www.sau.com.au/forums/topic/21421-changing-cam-belt/#findComment-454356
you might still wanna check it, up to you! maybe a lube mobile or something might be able to come out and do that check for you if you cant move the car around!!
shouldn't cost too much, our mechanic just did it for nothing so dont know the cost!!
hows the turbo sound?
have you cleaned the AFM? had something strange like that in the 33, it was only when put on boost, and would pop and shudder when accelerating!!!
turned out that the filter element came off and the AFM signal was out of whack!!
https://www.sau.com.au/forums/topic/21421-changing-cam-belt/#findComment-454379
yeh a mate of mine cleaned it for me, my car has been trouble since the day i bought it but i wouldnt swap the thing for anything, damn this lure, id be blinging if it werent for hte car.... well ill fit a new o2 sensor tomorow, see if that cleans it up, im gettin it dynoed this friday, so he should be able to see where the problems coming from
https://www.sau.com.au/forums/topic/21421-changing-cam-belt/#findComment-454388
just listened to your video, did your cars starter motor always make that sound after it started, sounds like it takes a while to retract!!! if thats hitting the ring gear might be making the sound but that doesn't explain the over heating!!!
yeah definatley check the starter motor cacuse the sound keeps going after the car stops!!!
https://www.sau.com.au/forums/topic/21421-changing-cam-belt/#findComment-454418
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
