Hey all im new to the skyline scene, Im a holden man myself and im looking for a weekender prety much (have vn wagon for work thats on gas so cheap to run ). Now with holdens the 5 speed is called a T5 and the 6 speed is a T56, the 6 speeds ment to take a fair bit of punnishment were as the 5 speed dusnt like it.
So what i want to no is what are the 5 speeds like in the 33 are they eqivalent of a T5 like in a commodore or they different?
Just want to no if they will take some abuse like clutch dumps and burnouts. The reason im straying away from commodores are that what i want i cant afford and the next best bang for buck i recon is a skyline because they are geting prety cheap now 12- 15 k for a half decent 1...
Im just not sure what to do. Just looking at the engine bay, chaning plugs looks like it would be a nightmare not much room around.
Sorry for the essay i just want to make sure i make the right descision
https://www.sau.com.au/forums/topic/214230-5-speed-in-r33/
Manual trans in turbo skylines are MX-7 boxes............same as turbo VL's but with slightly different ratios
I think that the cost of them suggests that they have a good reputation as a decent box
richard
ps. for the record, I am not having relations with the above member
Edited by rb
https://www.sau.com.au/forums/topic/214230-5-speed-in-r33/#findComment-3783134
richard
lol wats with the relations stuff? but yeah do they take abuse i wonder give it time for others to post but thanx for posting mmm so its a "mx-7" box
https://www.sau.com.au/forums/topic/214230-5-speed-in-r33/#findComment-3783276
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
