So its time for another, Slightly serious but more comedic Starlet Challenge.
As most of you now know the texikhana is in a couple of weeks, and i will be competing in my very own skyline, but with the approval of STEVE (N1GTR) we are going to hold another MIGHTY STARLET COMPETITION.
So basically whoever guess' the Starlets placing, from one all out hot lap, among the field of the texikhana's entrants,
will win a A HOT LAP IN BOTH THE R32 ON THE DAY AND IN THE STARLET NEXT TEXIKHANA
Here are some specs
*1997 model Toyota Starlet 3dr ADM (Aus Spec)
*1.3 ltr DOHC 4EFE or SR13DE in Nissan terms
*260,000+ Kms
*Shagged 165/75/ R13 tyres, all round
*Many years of shameless abuse from both me and Dj On Ice
*Recent Oil and filter change
*Rear end Parking damage
*Lightweight wheel nuts
*1 Skylines Australia Texikhana competition
*Skylines Performance sticker
*Several skidpan days
*New Clutch!!
*Fluffy Dice
(Yes I stole the info from the other post)
The last competition was the DYNO comp and it was alot of fun so lets get as many people as possible, Here is couple of links to get you fired up
The previous Competition
http://www.skylinesaustralia.com/forums/Up...-s-t205054.html
The Result
http://www.skylinesaustralia.com/forums/Mi...kw-t209462.html
And some pics of it in action
http://www.skylinesaustralia.com/forums/Mi...-T-t209586.html
So everyone's Guess' can range anywhere from 1st to 41st
1-DriftGTS
2-Ex!$t3nZ- I have faith in you...
3
4-Abo Bob
5-GoldZilla
6-evil_weevil
7-Haysey
8-DRD-00F
9-TiTAN, Dj On Ice
10-mccready
11-ZCR
12-msnismo
13-Duncan
14-skylinegtts
15-N1GTR
16
17
18
19
20
21
22
23
24
25
26
27-BNR32t
28
29
30-datto260Z
31
32
33
34-sl33py
35
36
37
38
39-e_Dog,
40
41-SECURITY
DNF-Baconer
Good Luck Guessing
Edited by TURISMO
https://www.sau.com.au/forums/topic/214239-mighty-starlet-challenge-no-2/
By the way, I was 15th fastest last year out of 40 cars
1
2
3
4
5
6
7-Haysey
8-DRD-00F
9-TiTAN
10-mccready
11
12
13
14
15-N1GTR
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30-datto260Z
31
32
33
34-sl33py
35
36
37
38
39-e_Dog, BNR32t
40
41-SECURITY
DNF-Baconer
Edited by TURISMO
Dont do it to yourself... Take the liner.
39th.
39th, Ouch what an Insult
I'm competing in the liner, this is just one lap in the starlet I have organised with the NSW guys for the MIGHTY STARLET CHALLENGE
Edited by TURISMO
1-DriftGTS
2
3
4
5
6
7-Haysey
8-DRD-00F
9-TiTAN
10-mccready
11
12
13
14
15-N1GTR
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30-datto260Z
31
32
33
34-sl33py
35
36
37
38
39-e_Dog, BNR32t
40
41-SECURITY
DNF-Baconer
YOU CAN DO IT, CUT HIS FCUKING HEAD OFF!!!!!!!
1-DriftGTS
3
4
5
6
7-Haysey
8-DRD-00F
9-TiTAN
10-mccready
11
12
13
14
15-N1GTR
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30-datto260Z
31
32
33
34-sl33py
35
36
37
38
39-e_Dog, BNR32t
40
41-SECURITY
DNF-Baconer
1-DriftGTS
3
4-Abo Bob
5-GoldZilla
6-evil_weevil
7-Haysey
8-DRD-00F
9-TiTAN, Dj On Ice
10-mccready
11-ZCR
12-msnismo
13-Duncan
14-skylinegtts
15-N1GTR
16-Tarmac-
17
18
19
20
21
22
23
24
25
26
27-BNR32t
28
29
30-datto260Z
31
32
33
34-sl33py
35
36
37
38
39-e_Dog,
40
41-SECURITY
DNF-Baconer
Edited by TURISMO
to be honest, I think I will be lucky to get in the top 20, all these top 10 guess are very flattering, but I'm going to disappoint a few "top 10" guess'
Edited by TURISMO
Only one week to go, So Excited
1-DriftGTS
3-MaTBoY
4-Abo Bob
5-GoldZilla
6-evil_weevil
7-Haysey
8-DRD-00F
9-TiTAN, Dj On Ice
10-mccready
11-ZCR
12-msnismo
13-Duncan
14-skylinegtts
15-N1GTR
16-Tarmac-, ~ Jay ~
17
18
19
20
21
22
23
24
25
26
27-BNR32t
28
29
30-datto260Z
31
32
33
34-sl33py
35
36
37
38
39-e_Dog,
40
41-SECURITY
DNF-Baconer
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
