Make: Nissan
Model: GTIR RA Edition
Milage: 140,000
Transmission: Manual
Colour: Black (Fresh Respray)
Complied? Yep and im first owner in Australia
RWC supplied? If you want
Currently registered? Exp 29/01/09
Price: $14,000NEG
Contact: Via PM or 0405 835 006
Comments / Modifications:
PLATES INCLUDED IN SALE
ENGINE:
Mines ECU
Sard FPR
Fuel Pressure Guage
New Injectors
Service just completed (Oil Filter, Fuel Filter, oil ect)
New Plugs and Leads
New Dizzy Cap and Rotor Button
Trottle Bodies Cleaded out
Power Steering Pump replaced
Custom Made Radiatior Plate
Custom made Rover Cover Plate
K&N Pod filter
3" Mandrel Bend exhaust (Dump to flex pipe recently replaced buy HiTEK)
DRIVELINE:
Custom Made Heavy Duty 600HP Clutch (using NTN bearing)
Clutch Fork Strengthened
Clutch Pedal Strengthened
Replaced Clutch Master Clyinder
Gearbox and 3 Diffs flushed using Redline Oil
Front wheel bearings replced
Shifter Bush replaced
SUSPENSION:
Nismo Struts all round with progressive springs
Longer Tie Rod ends with grease nipples
Front ball joints replced
Front and rear CUSCO strut braces
Front braided brake lines
Replaced front disc's (not yet installed)
ICE:
Kenwood 6.5” 280 watt speakers (front doors)
Blaupoint 6x9 350 watt speakers (rear parcel shelf)
Pioneer DEH-6850MP (OEL dispay, 3 RCA out ect..)
OTHER:
Original GTIR Floormats
Original Flare
Original NISMO racing Seat (factory optional) see pic below (worth $1000)
Aftermarket Racing Seat (drivers)
Front alloy bash plate
Car has been resprayed and not driven sice i have colour coded the car and put new front and rear bars aswell as new bonnet (only 2 weeks ago)
Remote Central Locking and Alarm
Clear Side indicators
Also got a full set of Lockwood White Dials (Cluster and center guages) not installed
15" Light weight Racing Sparco Wheels 195/55/15
Fog light's still to go in the front bar (Genuine NISSAN)
Turbo Timer (not installed)
Also got some spares like a top mount intercooler and some other stuff ect...
Images:
Edited by SerialKiller
https://www.sau.com.au/forums/topic/214240-gtir-1-for-sale-price-dropped/
  • 3 weeks later...
  • 3 weeks later...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
