Hi,
In attempting to track a trajectory on a map in Nissan datascan's "Map Trace" function, the TPS gets stuck on the minimum value. I recall that if U know the address of the TPS value, U can get this to work on any RB, SR, etc. My application is an RB20DET, stock CPU. Anyone know where the value is hiding? Also, any hints on how to extend the selection of available maps would be great.
https://www.sau.com.au/forums/topic/214246-tps-value-address/
Thanks for rply,
Take a look at
inhibit_harvest_url_ttp://202.43.224.130/
with the "inhibit_harvest_url_" bit replaced by "h" of course.
point 10.
10. Map trace
  • A real time trace of a position on the map. This function is only available for z32 300zx cars at the moment. If the real time TP value address is known the function can be set up to work on any Consult I Nissan car.
The TP address is the spot in RAM in the ECU where the CPU stashes the TP (throttle pos). In datasacn, you can tell the map trace function this address. Then the map trace function can get its grubbies on the TP. Next U watch the track of the trottle/rpm curve pass over the timing and fuel map as you wind the car up. When you get ot a place you dont like the feel of, or it leans out or pings, you can tweak the map there :D That's assuming you know how to down & upload the maps. That leads to my second question. Does anone know how to give datascan more (read my custom) maps? That way, I could read my values off the display instead of having to look them up in a seperate app.
Further to that, it just occurred to me that the real time TP address might also be a memory mapped I/O register that the CPU reads to get the TP. Either way, it gives access to the TP for this particular datascan option.
TP memory addresses for VG30DETT, RB20DET and SR20DET identified by current NDS users are already pre-programmed.
get the latest version if you're using an old one - there is an option on dropdown for rb20det?
i think thats the point of it - they will read the maps from the rom and then display your position on it. because from memory once you choose your values it will then populate the table (fairly slowly, so presumably this point its reading from the map) before it starts showing you the trace
Yes, this is the way my old version works. I can't imagine that that would change, but U never know....
Shame we have to pay for the new one (hence all the questions), but it's not much.
Now, let's pop that rom out, solder in the piggyback, wire it up and were away....
No more soot on the boot...... :laugh:
Have you looked into nistune?
Intended to get something like a type 2 board, but no s/w.
Also will look into PC BIOS backup/switch boards & software. These ECU eprom sockets are obsolete,
and I expect there is junk out there for nothin'
Plenty of time.... It's a slug & I'm old, and patient.....
  • 1 month later...
Hi,
So can this be done on and rb25det also?
    • I think you're missing the point here Duncan, I was trying to say that if you want to go fast around and have a spare $80K to $100K, easiest option is to just buy another car instead of modding your Skyline. Sure blowing $80k to $100K would make it fast, but then you'll have a car that you can't drive on the street comfortably. But use that $80k, buy a fast factory car, spend like $7K on AliExpress pipes, email tune, tyres, pads and you can be fast, not to mention now you have two cars.
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
