hi guys,
last few days we had a bit of rain here in syd, after this i have noticed i have mini fish tank in my taillights.
water has gotten into the taillight, what is the best fix here? where does the water get in so that i can seal it off properly?
my guess is that the seal has broken down with age...
thanks,
https://www.sau.com.au/forums/topic/214260-water-in-taillights/
Correct the original seals on the taillight have broken down....any decent panelbeater will be able to re seal for you. Just make sure to get rid of any water in there before you reseal.
An easy fix for you; i just ended up drilling a 1mm hole in the bottom of the lenses to let them drain and dry out as i had problems getting them to seal properly, you only see the holes if you're really looking for 'em.mines a drifter anyway so it doesnt matter too mutch!
all fixed now - i took out the lights, cleaned up the surface 'goo' with turps then refit them.
i used a mastic which is the best thing for the job, if u use a silastic/silicone it will dry to a hard rubber & can move or split over time...with mastic it never hardens as it always remains wet & sticky (just like the factory stuff they use)
i tested it with water - perfect :wub: easy fix
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
