As of today, Journalists will be wiriting up the new FG line up..
I got these figures from drive.com.au for the xr6t
0-100km/h: 5.1 seconds
0-400m: 13.4 seconds
Top speed after 400m: 172km/h
From the article:
For the record, the air-conditioning was on. There were no stunts, no tricks, we just squeezed the accelerator. It did it like it was brushing its teeth.
This not only makes the latest Falcon XR6 Turbo the fastest Falcon to date, it also shoots it to the top of the leader board in Australian performance cars. It’s faster than both the Holden V8s and its own big brother, the Falcon XR8 (which stopped the clocks at a comparatively slow 6.3 seconds).
Since the FPV F6 is expected to come with a 310kw figure, expect the 0-100 acceleration time be in 4 seconds and quarter mile in on mid to high 12 seconds
http://www.drive.com.au/Editorial/ArticleD...;vf=12&pg=2
Edited by Barbarian
  • Replies 71
Is it just me or does every photo of the new Falcon look like it has a really skinny trackwidth?
GT-R times will be much quicker than the Falcon.
I've seen a couple fg xr's on the road and they appear some what smaller than BA/BF's.. also from what I have read, tracks for both front and rear were widened.
Ford Aus promises this car to be the best handling Aussie built car to date.
hell yeah
bring on the fpv f6
it was always said that the BA/BF were the best looking fords ever built - i think they have surpassed that with the FG
very very stylish....
(i dont think there is a common exterior panel between the BF and FG)
i wonder :thumbsup: if it will have shitty ill fitting plastic bits in it and other things that fall off or break :laugh:
parents have a territory AWD ghia and nothings fallen off yet (and its 2 yrs old...)
Not bad. You'd think theyd release photos that aren't in a shit colour...
Car companies always take the most eye-catching colour since it photographs the best.
From Nissan's perspective, look at the horrible Sunset LeMans orange (and the new solar orange) that most of the 350Zs in the promo posters etc are shown in. Really vibrant when printed, and it comes off the background well, but in the metal its really tacky.
The old BA/BF performance Fords had their promo / press cars in that sickly green, too. Great to shoot, bad to look at.
    • Hi Everyone, I did 4.11 gears in my 34 GTR and only thing that remains is to fix the speedo reading (it reads about 15% higher) using the R33 GTR speedo sensor. Few questions:   1. Does the R33 speedo sensor fit right in to the 6sp getrag? I read it does but wanted to confirm because the speedo sensors between 33 and 34 look quite different   2. The connector on the 33 speedo sensor will not plug into the connector on the getrag. Do I just need to wire the pins together manually?  See pic: https://imgur.com/a/NTDzFe8
    • Does anyone know how I could find the part number for bolts used with  r34 with rb25detneo engine lower timing belt cover?   my timing cover was rubbed and i fixed it but upon putting the harmonic balancer i see the timing cover is almost rubbing and that is due to previous owners using general bolts and washer rather than the bolts per link below which sits inside the washer and pull the cover in   not sure if those bolts will fit rb25   https://www.ebay.co.uk/itm/326510870741?gad_source=1&gbraid=0AAAAAB_7XZxjuciMybdVOTShCs9857686&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338723872&toolid=20006&customid=7jIl12glAAAAVfHSSnyxAmSsdRxnAAAAAA
    • If the slightly higher internal EGR caused by a high flow cat causes detonation your tuner was way, way, way too aggressive to begin with. Timing scatter is a problem unless you go to a crank trigger, winter vs summer blend has different octane, list goes on.
    • The H1 Alpha with the 6.6 Duramax is basically the actual powerplant it needs to be remotely ok to drive on public roads. It's just not worth the cost to buy a real one. Humvees look cool but man the reality of them is depressing. Grunts aren't kind to them but they aren't that reliable either, they have horrible payload despite absolutely massive size, zero actual armor against mines/small arms, absolutely anemic naturally aspirated diesels, list goes on.
