Actually when I sit in my R32 GT-R & look at the dash I think "Fk I wish this didn't look like a VN Commodore."
LOL!
anyway i think this is a pretty nice car and would buy one just gota sell my car
  • Replies 71
Wow so the luxury model is faster?! Go figure ey...
I truly am a Ford man. I wish I could a afford a BA> XR8, because if I could I sure would miss my Skyline.
The FG shape really is growing on me. At the motor show I thought from the side view it looked too plain. Especially with the performance models there is no chunky side skirts of aggressive bodywork to really emphasise the Ford muscle under the bonnet. But as the days go on I'm liking it more and more... hard not to with those times!
Fear the twin-turbo V6 in 2010!!!
The W427 looks like shit?
Sure it's 7 litres and 370-odd kw but I'll bet it won't go that much better than the FPV F6 to warrant the extra cost. It'll be a car made for the die hard Holden fans (That'll probably get munched by someone that gets an F6 and plays with the power a little bit - or someone with an R35 lol)
I never said the W427 looked good, it was more about the quickest Aussie car built
I seriously doubt that ford will allow the turbo to be so quick.( 12s ). The trend in the past has always been to push the V8 for the top line performance car and the everything else after it. if the factory turbo falc is running that fast it will kill the market for the V8...As for a twin turbo V6 in the future model....I am a little sceptical they will do this,maybe if it comes from Ford US twin turbo, but I just dont see Ford Oz going down the engineering path trying to squeeze twin turbos onto a V6. Its a far more expensive excercise than the single turbo straight six currently in production
they are going to market them xr6t n xr8 on same level. gone are the day's where the xr8 was supreme..... they actualy are ALOT different to drive overall then the previous ba/bf.. totaly re-designed over all, alot of work has gone into this thing... its going to be a good thing.
    • On the compressor side it looks like the best, if your head setup will support doing 100-110lb/min at 30psi-ish boost.   The G45-1350 compressor looks ideally better if you need closer to 40psi for it, given both the G40 1150 and G42 1200 look like they'll be around the 100lb/min mark at 35psi and dropping from there.   Bear in mind the turbine sides are all different between those three turbos, so that COULD be an influencing factor for how they all perform in the real world as well.   Not sure if you've made a conscious decision to only look at Garrett or not, but at least on paper the XRE7169S matches or beats those other three at everything from 30psi up and just going from wheel size alone likely to be at least as responsive as the G40 1150 and seem to behave closer to G42s in terms of turbine flow.
    • @Lithium  looking for a turbo for my Rb30. Want to make sure I understand this correctly.   If I want to stay 40psi or under my best choice of these 3 is actually the smaller G40-1150 ?
    • Massive ups for MTHire also. Could not have done the subframe bushings job without hiring the tool from them. Process was super easy and cost me around 25% of the cost of the tool. If you need a tool to do a one-time job, check them out. (Paid for the rental myself, no sponsorship here.)
    • I'd suggest calling Unigroup, they have a lot of experience with these, access to reliable fabricators etc. Of course it will cost but at least you can trust what they tell you
