there are a few cool installs. Craved is working on one which is a replacement for your washer bottle. half is for the washer bottle and the other half is for a catch can. check the fabrication section.
  • 1 month later...
Hi,
Love those installs and about to do mine, but the piping that came with the can is too small! >_<
Was looking on Nengun and there seems to be piping options of three sizes - 9mm, 15mm, and 19mm - which is the right size?
Thanks!
Peter
Hi,
Can anyone tell me what the correct size piping is too fit onto an RB25DET please? Is it 9mm, 15mm, or 19mm. I know that Toyotas and Evos use 9mm, and S13,14,15s use 15mm - do Skylines follow suite and use 15mm as well?
Thanks,
Peter
    • Just buy a BMW if you want that... You can then choose whatever engine of theirs you want 😛
    • Clear vinyl wrap or clear coat?
    • There really needs to be an ODBII item that can play intake noise through speakers, synchronized with your current RPM and TPS%.
    • Worth most of the $50k alone!
    • So, we now have a straight and clean boot lid inbound and the car goes in for paint, again, on Wednesday, and will be ready on Friday, all ready to get cams and stuff on Monday  And by straight and clean.....I mean a brand new OEM one that cost..... $1300....😪 Sadly there's no clean undamaged used soft top version available, plenty for the power retractable hard top versions though, which is arse and makes Mark have the sads I could have waited longer, until a NC sort top boot lid eventually turned up, but I'm sick of waiting and said fark it and made it rain cash, meh In other naturally aspirated news, one of the guys at work brought in his old Corola which had a 4AGE in it, really nice clean car with lots of mods, including ITB's, man that things induction noise sounds sick with all of the dorts that makes you smile......maybe the NC needs ITB's, yeah, basically for the noise they make, but they're pretty expensive, but, they sound so damn good I may bring this up when I drop the car up on Monday, and by may, I mean I will🤣🤑🤪🤣
