Hey
I am looking at getting a digital camera, nothing too fancy but something decent - basically a camera where I can just take photos
Basically I need it for taking basic photos, indoors and outdoors but I want good quality and not something thats slow and ends up taking crap photos - point and shoot camera!
I have the following 3 in mind but I can't decide which one would be best to get, any ideas?
SONY CyberShot W80 : http://www.sony.com.au/dis/catalog/product...ategoryId=22119
SONY CyberShot W55 : http://www.sony.com.au/dis/catalog/product...ategoryId=22119
CANON Ixus 70 : http://www.canon.com.au/products/cameras/d...italixus70.aspx
I've read some review but they are all pretty much the same - CANON is the cheapest, then the W55 then the W80 being most expensive
If someone can recommend something else feel free, I'm looking at spending about $300
:thumbsup:
https://www.sau.com.au/forums/topic/214333-what-digital-camera-do-i-get/
  abu said:
haha na thats just a link to the page, you have to select w55 or w80 from the right side :thumbsup:
aah right
ive heard from a few different people that these are good
http://www.panasonic.com.au/products/detai...m?objectID=3121
suspect a bit more than you wanna spend though..
  ZENNON said:
you want something compact specifically?
i have older version of this and IMO its fantastic for a P&S
http://www.fujifilm.com.au/products/item.a...d=1&pid=330
Whats that one worth?
Yeah basically something thats just a point and shoot camera and takes good quality photos
  ZENNON said:
aah right
ah to much man
Personally I'm a huge fan of Canon, they're easy to use, you have a multitude of 'manual' functions that most other 'point and shoot' cameras dont have and they're quite hardy for how small they are.
in my time I've had an:
A70 - stolen
Ixus 60 - GF's point n shoot
EOS 20D - my toy
anyway, best way to find out what camera you like is to go into a shop and spend 1/2 an hour playing with them...
    • I've done this both ways, I'd use the original loom & swap plugs on the engine side as you'll usually end up changing a lot of those anyway. Series 1 is usually non ABS which requires wiring which I can't remember how to do as haven't done it for over 15 years. The auto inhibitor is easy to bypass or in the meantime you can put it in neutral & unbolt it & tape it somewhere in the bay haha, then just wire reverse lights. I'd go straight to aftermarket ecu. A few basics are built in ignitor coils & reverse the CAS wiring, sort the plugs for whatever injectors & IAC-you can use an adaptor for the neo type otherwise the s1 will still work, use the knock sensors that suit the loom & it'll be pretty much running.
    • This is for an RB20DET. Sorry for not including that.
    • Welp, this is where my compression lands after my rebuild. Thoughts? I have ~6 hours on the motor.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
