hi all, im very new to this forum, i have tried to find an answer to my question but searching
but i couldnt find and threads in relation to it so im just gonna ask it again,
My R33 has recently started to surge, and want to cut out just as the turbo is spooling up,
and sometimes while i am just driving at the one speed, but is worse while accelerating..but only does it
when the engine is warmed up, never does it when it cold.
the best way to describe it is, it feels like its running outta fuel (yes there is fuel in there!)
could it be the igniter packs?
any help would be much appreciated,
great forum by the way!
cheers, craig
https://www.sau.com.au/forums/topic/214337-rb25-surging/
I have this problem after I fitted a electronic boost controller and turn the gain or boost level up. But when I turn the boost level or gain down the problem always goes away. Sometimes with diffrent fuels the problem would come back so I had to change boost / gain levels depending on the fuel. Fo you have a boost controller fitted?
https://www.sau.com.au/forums/topic/214337-rb25-surging/#findComment-3785564
if it sounds like its popping its probarly the coils
but if it making all the right sounds but going no where then takes off like a bat outta hell
it will be the normal r33 flat spot
most people change the ecu and have it tuned to fix the problem
but there are other ways around this problem it just depends who you speak to
https://www.sau.com.au/forums/topic/214337-rb25-surging/#findComment-3785608
Are you running standard boost? If yes then it's not the boost cut.
My advice:
Do a search on-
O2 Sensor/oxygen sensor. Yours might be dirty/dying
AFM. It might need a clean
Spark plugs. Change them
Coilpacks. Wrap them in tape/silicone
Fuel pump. Maybe yours is on the way out. Change the fuel filter too, it's a good idea anyway.
If the problem remains after all those then get professional help. Or a psychiatrist.
Edited by R338OY
https://www.sau.com.au/forums/topic/214337-rb25-surging/#findComment-3785641
as far as i know, the turbo has been a flowed, but seems to now be running less than the standard 7 psi, i only have a manual boost controller under the bonnet, ill change as much as i can, coils, spark plugs leads etc, if it keeps happening, ill just have to take it to morpowa, or boostin oz to get them to figure it out...thanks guys
https://www.sau.com.au/forums/topic/214337-rb25-surging/#findComment-3785708
ok, i took the coil pack cover off, gave it a thrash to make the engine hot, it didnt do it, except for when i first started driving (when it was cold)
i got home , turned the lights off to check for a sparks fromk coils, and there was nothing.
i bought some new ngk laser platinum spark plugs that will be going in tomorrow.
could this problem possibly be my AFM?
https://www.sau.com.au/forums/topic/214337-rb25-surging/#findComment-3789011
ah ok.. 2 of my friend's r33 had the same problems too
put it on the dyno and check the fuel pressure, might be your fuel pump
may also be fuel pressure reg too, though not very likely. i'd check fuel pump first
coilpack and afm are other possibilities, but if afm's cleaned like i've mentioned in the other post it should be fine
if afm is playing up or dirty your car wont idle properly in most cases
Edited by chiksluvit
https://www.sau.com.au/forums/topic/214337-rb25-surging/#findComment-3789139
ok, i spent some time under the bonnet yesterday, changed spark plugs (ngk laser platinum) cleaned afm thoroughly and checked/cleaned igniter packs, also wrapped them in electrical tape just in case,
all seems good, no more surging or choking, but this typical r33 flat spot you all spaeak of is now obviuose, doesnt do it all the time, but every now and then when i boost it hard. for now, it doesnt really bother me, it still eats most ls1's so thats all im worried about at the moment ; )
i also took out the bleeder valve beacause it wasnt always hitting the 11-12 pound it usually does, instead it was only reaching 5-7 pound.
it didnt seem to make much difference without the bleeder valve, but does it matter if i leave it out?
https://www.sau.com.au/forums/topic/214337-rb25-surging/#findComment-3791059
taking the bleed vavle out definatly wont hurt anything
the flat spot though i know how to fix it without changing the standard ecu
i have done it to my car and many others and has worked everytime
ok...how?
https://www.sau.com.au/forums/topic/214337-rb25-surging/#findComment-3791145
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
