Just installed my new RACE TRACK spec D2 coilovers on my nissan gts r33 98 model (only drive it on track days), took it down to the track and the car literally sticks to the ground, huge improvement for a reasonable price.
I found that the harder I adjusted the damping the more stable it got on corners. The Maserati behind me was all over the track going off the chicanes it was a laugh. But my car cuts off so given up after a few laps.
Rear: 3.0 turns from hard
Front: 2.5 turns from hard.
Will try harder settings next time.
https://www.sau.com.au/forums/topic/214339-d2-suspension/
Where is your local track. What other mods do you have and what tyres were you running? I only ask as i find peoples opinions on suspension vary greatly, so to me the real indicator of good suspension is the pace it can be hurried around a track. I drove a guys neat R32 GTSt at Eastern Creek a few years back. Had more power then my car, no speed limiter and about the same tyres. I have better brakes...and i was able to circulate almost two seconds quicker in my car then his....he jumped from mine wanting my suspension as whilst his was way firmner mine gripped a lot longer.
So what feels tight and grippy may not really give good traction, even though it may be to the owners liking or what he feels handles good. LOL hanflign does not equal traction :down:
https://www.sau.com.au/forums/topic/214339-d2-suspension/#findComment-3785857
ok well 1st off what were u running b4? of course it is gunna feel like the bomb if u've just been rollin round on stock suspension
again what tires, if there not the same as u ran on ur previous setup then u may need to factor that in
how did u change the geometry of the car (camber/toe/castor) also as its been mentioned dropping the car 100mm is gunna help feel and performance
also be carefull comparing to other cars on the track cause driver skill come into it ALOT more than the car, i've beaten 400hp GTR's around a track in my old car with 150hp and busted ass JIC's
also u list ur prefered settings for stiffness and say that u wanna try stiffer, were u being timed? and did u compare times to setting to find the optimum?
i dont doubt that ur car does indeed go better with these coilovers than ur std suspension... however these cheap coilovers D2's G4's and ISC's simply do not have the R&D put into them that they need. they use overly stiff valving and spring rates to make it 'feel' faster and more fun to drive, but infact if you push it to the limits they simply cant provide the grip that a quailty product can. i have custom bilstine coilovers all round on my car (track only) and i love them, they're softer than my previous jap spec coilovers but provide much better grip through both the tight twisty stuff and the long sweeping bends; admitadly it is too soft for drifting and as thats the direction that i wish to take the car they will have to be rebuilt to new specs, a costly and time consuming exercise, but necessary if u truly wish ur car to handle
basically what i'm saying is they're good, an improvement over std, but there is alot better out there and personally i wouldnt touch them (quality products will also last longer)
https://www.sau.com.au/forums/topic/214339-d2-suspension/#findComment-3785999
well gentlemen, let's not overcomplicate things.
R31_pwr how do u know that D2s don't have R&D put into them? :D
comeone fellas, we all know who the big players are and many people fall into the trap of paying the extra 1,000 bucks. there are people that bash teins, ohlins etc..I know a guy who suggested buying USD 20,000 suspension saying they were the best. By the way D2s are not cheap, I think they are reasonably priced rather haha..let's not get corporate...but anyway who knows I probably will try the others as time goes by and the track gets more serious. By the way we're doing trackdays in Dubai at the Dubai Autodrome.
Roy I think you were faster due to skills maybe, but let's not forget NA are generally lighter than the GTSt. Also luck plays a role as well as he may have slipped for a split second which accounts for the time difference.
I think my current Marshal KU17 92W R16 are ok but I might need to upgrade to steel re-inforced side walls. I am working on the car, have been for 4 months now and there always seem to be improvements to be made.
https://www.sau.com.au/forums/topic/214339-d2-suspension/#findComment-3786360
We swapped keys, he drove my car for a session and i drove his. We both agreed that my car was a little more dull but had more grip and the times it did showed. Hios car was tighter and dartier, but less grip and slower. Could have been tyres, alignment etc etc. So, meh, not sure how much water my point holds. Before after times etc always make a good indication rather then seat of pants :D
https://www.sau.com.au/forums/topic/214339-d2-suspension/#findComment-3786402
i didnt say that they didnt have R&D put into them (any new product has to) what i am saying is that its not suficent. also the build quality is poor, i have seen the mounting brackets (S13) snap in what could be deemed as a small incident (car got about 1 foot of air)
these coilovers are built in china on a tight budget and it shows, unfortunatly most people that would even consider fitting these to their car would think that they're the ducks nuts cause all of a suden its a stiff, jumpy and 'feels' exciting which 'feels' fast... it took me a while to learn that a boring ride/drive is often alot faster :D
https://www.sau.com.au/forums/topic/214339-d2-suspension/#findComment-3786509
  • 1 month later...
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
