  • 2 months later...
i was thinking about this myself but im a bit confused,teehee.gif....on a s13 when you turn up the heat for example or change the heats direction from say the window to the vents with the digital unit isnt all this done automaticaly in a s13 with motors?wear as in the cefiro its done manualy by hand.did you have to put in motors ect?or am i totaly wrong and confused hear?
i think your both wrong and confused, what is being said is once you pulg in a digital control on a non modified wiring plug you will blow a circuit effectively making the unit work as it did before( blow air etc ) except for when you modify the wiring to make it work something will be wrong with the unit.
from what i can see when you plug the unit into and unmodified loom it will do damage?anyway thats not what i was on abut my post was in refrence to the original poster off this tread and the fitting off this item correctly as im wanting to do this myself,in an s13 usuing the digital unit,isnt air directing,air tempetaure controlled automaticaly by motors opening and closeing vents behind the dash?in a cefiro isnt done manualy?i know some off the functions are done off a switch but like the hot/cold is turned up and down manualy by a leaver is it not?
No.
Cefiro air con looks like an analog piece of shit, but there is no levers / cables etc.
Cefiro stock air con is actually climate control.
Take it out of the dash and have a look.
And dunno wtf you smokers are on about :P Tested my unit twice against 2 different cars - works fine, still.
  • 2 months later...
  • 1 year later...
  • 4 weeks later...
K I think I got this figured out for the our cars but I rather just buy a harness from someone then re-pin one, dose anyone make one for me or know where I can get one??
  • 3 years later...
  • 7 years later...
For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc:
https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm
"Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it."
Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31.
I'm decent with wiring but feeling kinda lazy about taking this on.
Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx
"After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)."
Lol wtf
Edited by S1_C34
    • Big single, and seqy. #sorted
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 😛
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
