hey all,
As some of you might know i work for CBC and im just letting you all know i can get Wheel bearing kits for R32, R33s, i havent looked up R34s but im pretty sure id b able to hook something up.
im at the holden hill branch on North east road, ask for me and ill look after you all :D
(also do gates racing belts (alt, A/C, P/S), timing and tensioner kits)
cheers joel.
https://www.sau.com.au/forums/topic/214386-skyline-wheel-bearing-kits/
hey all,
cheers joel.
Got a ballpark figure on them 'discount' kits?
:D
when i turn my A/C on it makes a very bad squeaking noise.....does that mean my belts are stuffed or the tensioner pulleys are on their way out.....if so can you please PM me a ballpark figure on those for a r33
Joel will be dropping sometime soon for some of the Gates auxiliary belts. :blink:
Check for wear on the belt first, otherwise it just needs tightening up.
Hello,
I was up there the other day to get an o-ring for a oil filter bracket i was making. I saw your skyline at the door but didn't know you were a SAU member. Can you give me a price on some S13/180sx front wheel bearings ( i think i know who much they are, last time i was quoted $90). I Know your timing belt tensioner and idler kits were sh#t loads cheaper than Nissan's price.
Thanks
Dale
Edited by D_stirls
You're not kidding there when I did my 100K kms service, I had to go through Nissan (paid almost $400) cos CBC were out of stock & all their interstate suppliers wouldn't sell theirs to them as they were running low as well :blink::down:.
hey yall
i just got in 2 Front wheel bearing kits and 2 Rear wheel bearing kits.
retail they are like $150 for fronts and almost $200 for rear lol but i can do them for closer to 80-90.
D_stirls ill look into it for ya bro. just give me a bell just incase i forget ;p.
it sure is mine nightcrawler but its a 2 door O.o and the front bar aint tidy at all lol. just hit a damn curb the other day. still spitting chips :P
cubes i can hook you up on the belts but im not sure about the tensioner pulley. (lol i was gonna say bring it in for me to look at but i got 1 on my car LAWL) ill see what i can do there :D
cheers.. CBC definitely do a suitable bearing as I have replaced it some time ago but the old man with and his ham fist buggered the pulley smacking it in, now the bugger causes the belts to squeek.
I've grabbed another will pop the bearing out with the press and bring it in. The press has to be one of the best tools I've bought; used it for almost everything. :P
Any idea what I'm looking at for 3 of those gates belts? powersteer, a/c and water.
around 20 each id say man, maybe a lil less.
they are
4pk835
4pk925
4pk945
im pretty sure they are the ones on mine.
ill have to get them in from VIC so call me up first cubes then ill buzz ya when they are in or something.
i think i might need some front wheel bearings. ill sus out my car and see if it is the bearings going out.
might just get front and rear bearing at the same time.
could you tell me a price and ill come in and get some off ya.
cheers
Can you help me out with a price to replace the bearings in my hubs
the front are stagea awd and the rear normal gtst and do they come with seals, do you do seals, or do i get those elsewhere
this is for a 5 stud conversion hubs are'nt in the car yet
thanks for your help :D
nps adrian :D
steve the Rear wheel bearing kit doesnt come with a seal but its not a normal tapered roller bearing (most common wheel bearings). Ive never pulled my wheels off so im not sure if a seal is needed, i wouldn't think so seem as the bearing is sealed already, but yes we do have seals and get get pretty much any seal under the f**king sun ;) As for the fronts ill need to know what year stagea they are from and we can go from there.
cheers
  • 3 weeks later...
    • God I love shiny engine parts 🥰 Are you looking for more horsetorques in the mid range? (Smaller cam) Or just more horsetorques every where? (Big heads and bigger revs) Assumption: they were not bought late night shopping on the interwebs after drinking too many beers, which is typically how I pull pins on things......🤣 The evolution of your car is coming along nicely, I sometimes wish I didn't get bored with my cars and keep flipping them, maybe the MX5 will be different
    • I got the hazards working! Turned out it was disconnected! Indicator stock still isn’t working. I took the steering shroud off and there seems to be a third connection missing I see two small white connectors but they don’t fit the indicator switch unless they need a short lead to convert the connector type. Can someone point me in the direction of the wiring diagram for the indicator switch?   https://share.icloud.com/photos/0e8ReiFSLBVJsTPUKKfA_1IdQ
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
