Looking at doing a single turbo conversion.. what i want to know is what is the biggest i can go is with standard internals..
on around 10 to 14 psi..
I have power FC, Split fire coil packs,exhaust, upgraded fuel pump and presaure reg,
If someone could tell me what size i could go to and what other suporting mods i would require that would be great. aprat from the obvious manifold wastegate etc.
Thanks guys.
https://www.sau.com.au/forums/topic/214389-single-turbo-conversion-question/
i just finished my single turbo conversion on my R32
the only internal work i have atm is HKS step 1 cam shafts 264 intake, 264 exhaust and HKS adjustable cam gears
i first went out and bought a T04z but sold it for a Gt3540 with .78 divided exhaust housing
i bought the small exhaust housing because i dont wanna rev the engine hard with standard bottom end and standard oil system
all im waiting on now is a clutch and ill be ready for a tune
my list of supporting mods
TiAL 44mm gate
custom twinscroll steam pipe manifold
hks cams
hks cam gears
sard 800cc injectors
sard fuel reg
apexi power fc D jetro
blitz boost controler
full exhaust
115mm intercooler
fuel pump
its realli only a basic build just bought every thing which i needed to support the turbo setup
Thanks mate your a legend.. will help heaps when i start ordering stuff..
Ill rebuild the engine later on down the track. he he.. maybe after it blows. Jokes. :-)
yeah im in the same boat as u
i dont wanna rebuild my motor unless i have to
so im gonna enjoy it for as long as i can and when she lets go and doesnt wanna play any more ill go threw the rebuild
I have a single turbo gtr, and have tuned quite a few. IMO i think they are overrated, for less $$$, you can keep twins, get better response, and make far more power than the standard engine can handle. Dirtgarage is making close to 500awkw, with lowmount turbos. They stock rb26 internals are really only good for a long term 320rwkw, any more and it will go, just give it time.
It took me a long while to realize, theres a perception that BST or MST make more power / better response then low mount twins.
People must just like the idea, of replacing two with one... or like the look of a stonking great high mount :P
Diff ways to skin a cat, each to their own i guess.
i have a single on mine and if u plan on workin on the engine at all i would never ever ever put a set of twins on a rb26, they are a pain and a single turbo frees up sooo much room in the bay and simplifies things. My mate runs a gt3040r on a 3L 7m and makes 440hp at wheels on 19psi, and it is absolutely great for response, if i ever downgrade i would choose one of those for track work.
external wastagates are also nice as an added bonus :P
Yeh but you can get 440hp atw's from a lowmount turbo upgrade with better response :D
yer but if u plan on ever workin on it i bet ya turbo removal takes longer than 30 min :) or getting those dump pipes off are great fun on stock low mounts. I know alot of u guys dont touch your cars and leave it to mechanics but if u do then u will understand if u seen a single turbo setup compared to twins.
why would twin low mounts have better response? alot of these supposed good response lowmounts i see arnt making decent boost till over 4000rpm anyway which isnt so crash hot im sure a gt3040 would be as good and if not better considering it makes full boost under 3000rpm on my mates 3L.
I think alot of you guys think single turbo = t88 or gt42 or t04z even and there is such thing as small single turbos that still make 500hp at wheels and come on boost early in the rpm.
twins are good from a legal looking engine bay point of view, but i personally will never use twins again unless i want redicilous power and go twin high mount 3037s or something.
this is just my opinion and everyone has there own so make what you will of it :)
Edited by unique1
    • I see... Any idea how much fab work is required? I note the Hygear megathread but its like 900 pages
    • I should try the experiment you're talking about, the throttle switch is still there carried over from the R32 and it's still all wired up but after I did the whole intake manifold refurb and had to recalibrate the TPS I managed to somehow get the idle switch reporting activation at 0.22V, then when I adjusted it to 0.45V for idle it decided the engine was permanently no longer idling which caused some very weird behavior, closed loop idle was disabled so it would basically be at the whims of the cold start valve and whatever the base timing table was at. Then just unplugging/replugging the TPS with the ECU live caused it to relearn the idle TPS position and decide 0.45V was idle. Presumably there's nothing in the TPS that allows for the throttle switch to "recalibrate" like that, not easily at least.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
