Hello All,
Currently having trouble with my r32 and the electrics in the damn thing. When its running its running fine however just a week ago i was driving along and the entire car cut out. taco said 0 and i was rolling. luckily enough about 5 seconds after it happened it was jumped back to life and i was on my merry way again. it did it to me twice more that day. both times again just a momentary 1-10 second lapse in power to my car.
got home and cleaned the bajesus out of the battery terminals and drove it all the next day without a problem but sure enough the next day it started again, killing the power while driving. pulled up and did some things for about an hour, jumped back into the car and nothing, i could hear the starter motor cranking but there was no life other than that in the car. got it towed home and sitting in the driveway after it had stopped moving, had the key on for the steering lock and what do u know all the lights came back on. keyed the car and away she went. :D
so from my observations so far i can tell you this.
normally you put your key to on, all your dash lights come up (hicas etc). when the power cuts i get no dash lights @ all. my indicators dont work however the hazards lights do. my stereo still works fine. i can key the car and all that happens is i hear the starter motor cranking hard.
i have an immobilizer in the car and i initially thought it could be that however i got the manual out and the LED seems to be doing what its supposed to do. also i tried using a blank key without the imobiliser key/stick/pill (whatever u wanna call it) and that doesnt even allow my starter motor to crank so im assuming it isnt the imobiliser however thats where i'll start tomorrow.
the worse thing now is, its in my garage and is starting every time again :D however i know once i start driving it'll do it again so its a bit of a biach....
if anyone has had a similar problem or the exact problem please let me know or if anyone can shed some light on the situation it would be greatly appreciated :down:
cheers and thanks in advance,
Evan
https://www.sau.com.au/forums/topic/214397-electrical-fault-1992-r32-gtst/
  • 3 weeks later...
When u say the starter motor is cranking, do u mean it is cranking the engine, or ticking? I've had a similar problem last night. I have a 92 32 gtst. Was driving everywhere and all was fine. Stopped at a servo, got some food, came back to start the car and the reds came on, flickered a bit then i tried to start it. No start. Just ticking from the starter. I clutch started the car and it ran fine.
The conclusion i have come to is that the starter has an internal short causing power to surge and cut out.
I'm going to put a new starter in it tomorrow and see how it goes after that. Will keep u posted. Hope that helps and good luck with ur problem.
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
