i wouldn't bother with doing poncams it will eventually destroy your bottom end they are good for power but only if you are looking for big numbers and require taking the engine apart, also dont bother getting 1000cc injectors again only needed for big power aplications 250rwkw is a big number and very streetable and you would only need 550cc injectors for that and they sell for about 600 a set.
Have a look in the traders section for mechanical parts (dont buy them second hand your asking for trouble) and you should be able to pick up a profec b and power fc from someone pretty cheap just look around
My 2 cents :(
lucky its worth 2 cents, cams will not destroy your motor...
sorry guys i was going to do this myself so i asked my mate who is a mechanical engineer and has been working on engines his whole life and he advised me against it as he thinks they can eventually destroy the motor
EDIT
sorry guys miss i miss understood what he said, he said that it will destroy bottom end power not the bottom end whoops :D
Edited by WA_R32
this is what he meant
Cams won't destroy the bottom end of the engine, they will destroy the low end power. Its fairly complicated how it occurs. But basically a high lift camshaft will allow air a larger gap for air to get into the engine. This means that the velocity of the air entering the engine will be lower. If the velocity becomes too low, it reduces the turbulence of the airstream and the atomised fuel begins to condense into droplets. These droplets will lead to poor combustion as liquids don't burn. During combustion these fuel droplets are evaporated by the heat of combustion, all of the energy that goes into evaporating these droplets is no longer available for pushing the piston down. This is also why your fuel economy will get worse, as more fuel will need to be injected to get the same amount of easily ignited atomised fuel. However the aspect of a lumpy cam that has the greatest effect on low end power is the duration (how long the valves are held open for). There are a number of factors that cause this, but the easiest to explain, and probably the biggest contributor to a loss of low end power is the fact that a long duration camshaft will hold the inlet valve open longer. A long duration camshaft will hold the inlet valve open a considerable amount of time after bottom dead centre. At high rpm the inlet gasses are moving so fast that they have a considerable amount of momentum. Holding the inlet valve open past BDC takes advantage of this momentum allowing more air into the engine (air continues to flow into the engine even fter the piston has begun to travel upwards). However at low rpm the air has much less momentum, and consequently some air can actually be forced back out of the engine before the valve is shut. A similar thing occurs in the exhaust, except that the exhaust gasses are let out too
early. There is also the possibility of inlet gasses being sucked out the exhaust during the valve overlap period.
not confussing at all
Oh I see...
The thought of cams cracking the crank case seem utterly ludicrous... I was about to call greylands ffs....
But all is gud now! :P
Edited by Marco-R34GTT
  • 1 month later...
Blitz thunder bahaha
funds DID permit but now i've run into a bit of financial strife...
a few things can happen in the position i'm in at the moment...
car doesn't sell = cosmetic plans first... ie;
FULL URAS kit so that means new Front Bar, Side Skirts, Rear Bar WITH Vented Bonnet in black and boot in black... no wing and new rims...
then i'll move onto the FMIC and PowerFC and Fuel Pump...
Injectors and Turbo can come later...
i'll be doing the interior before i do the turbo and injectors...
if i DO sell then i have two options... ie;
buy my brothers TME... if he's sold that then i might have to go the Blitz 4 door Thunder and it WILL be manual turbo
i want the decals and all, man that car makes me melt
