  • 7 months later...
i know im bringing up the dead, but its better than making a new one.
is there any changes i should work with?
since im having ER34 N/A and i'm dropping off RB25DET NEO. what about the flywheel? pull push clutch, gearbox? turbo lines?
any more detail information could save my $$$ eventually.
cheers.
the whole undercar setup between N/A's and turbo's are difference. after picking out the differences, youll look at it and realise just how different the two models are...both look the part though :P
the whole undercar setup between N/A's and turbo's are difference. after picking out the differences, youll look at it and realise just how different the two models are...both look the part though :angry:
Tell me about it! Worse it seems if you own a Sedan ~_~ Unless of course if it's a GTV
R34 GT doesn't have HICAS (4 wheel steering) Traction Control (TCS) or Limited Slip Diff (LSD)
R34 GT does have an LSD as an option - Its on the original R34 Skyline brochure from Japan - RB25DE models only :P.
i read the manuals, it says the N/A one use R200V lsd type.
but how about the tie rod, castor rod, camber rod?
i know they have different rear suspension setup, does it means i have to look for a different rear swaybar and anti-rollbar as well?
well, at least im getting a r32 gtr brakes now.
cheers.
  • 1 month later...
Sorry to revive an old thread, but i thought it was better to revive one then to create another identical one. Basically im looking for a way to check if my engine is originally from a turbo or non turbo R33. eg if the person just bolted on turbo bits or if they changed the whole engine. I know my skyline was originally (factory) non turbo as the badges are blue, open diff (until i got to it...) and no hicas.
I know the compression seems to be the only difference and thus i will do a compression test once i get my compression tester back from my brother..
Can you tell anything from the engine number??
Mine is: 181875A
cheers guys.
Is there little-to-no lag? aka pretty much instant boost? Badges doesn't mean everything, but blue badges are typically on N/As.
Are the wheels and brakes R33 GTSt items? 4 stud wheels and 2 pot front and 1 pot rear calipers were the go on GTS, whereas GTSt has 5 stud wheels and 4 and 2 pot calipers.
I'm not entirely sure from the engine number, I would assume that you can get some info from it.
Is there any Queensland mod plate to evidence any engine change?
Could even be that the owner put blue badges to fool other people in the know into thinking that it's an N/A.. but then like you said open diff and no hicas... Not many people do bolt-on conversions.
Do you have pics of the engine bay and other areas to try and discern whether it's a bolt-on, engine conversion, or just a bit strange?
my Na r34 has red GT badges :) they were there when i bought it tho.
And for the R34's, isnt it like ER34 for the GT's and something like HR34 for GTT's?
You could also check the coil packs??? different coils between turbo and non turbo
p.s
in New Zealand you can search the number plate and it gives you all the information about the car and what it was imported as etc etc
Edited by R34 -_-
i think he wants to make sure that his engine hasn't been swapped, not if the car itself is orignally a turbo.
the easiest way to tell if it is a turbo motor that has had the turbo removed would be to put it on a dyno. if it makes over 100kw then it is a NA motor, LOL.
you could probably also look for blocked up oil and water lines. although i guess that you would be able to tell if it was originally a turbo motor just by driving it. if you test drove other NAs when you were buying yours then you would know straight away. a turbo converted to NA would be dramatically slower than a stock NA. if you get easily beaten by v6 commodores would be another indication, LOL
N-DAWG,
Yeh there is little or no lag coming onto boost, the wheels are the typical 5 stud r33 pattern. I know that the badges aren't everything though it was the complete absence of any sign of the hicas system which really set me off.
There are no modification plates on the chassis beyond the usual import plates. Thus im thinking that the conversion could have been completed before it was imported though Im really not sure. I'll grab some pics and post them up today.
R34- -,
I know about the coil packs, though they would be easy to switch them over.
What im looking at is seeing if the motor is a turbo or non turbo from factory. Reason for this is obviously about the compression ratio in the engine and my ability to boost it up. As it sits I can't see anything on the engine itself that points me in either direction...
Cheers guys
that will only tell you what sort of motor it was supposed to have (turbo or non turbo and what capacity). won't tell you the engine number to see if it has had a replacement engine put in that was the same type though.
  • 1 month later...
Hate to tell you, but FAST won't tell you what vehicle an engine number came from: However i can certainly help out HERE
This is my data on the above.
I am releasing a website next month dedicated to RB's with a much more comprehensive list.
As for differences the heads are a different casting in R34 non turbo to turbo, have smaller ports and runners, which is to do with torque.
if your more interested, PM me and i have allot more information.
just so you know, if your website mentions RB standing for "race bred" i'm going to find the server it is located on and set it on fire.
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
