Hey trouble with my R33...
Some background: everything is stock except for a pod filter...
but in the mornings when i hop into my car, everytime i brake i can hear a grinding sound coming from the brakes. But later on when the car is warmer, it doesnt grind anymore, can anyone help me? :blink:
and also...
Everytime i go over bumper my back suspension gives out a squeking sound... does that mean i need new suspension?
Thanks for everyone's help!
Joe
https://www.sau.com.au/forums/topic/214440-brake-problems/
Its dependant upon the brand and compound of your brakes. Some brakes take time to warm up, so first thing they may sound grinding until they warm up. Most people who go and fit aftermarket 'race' style brakes are not aware of the warm-up time. Some performance brake pads and not suitable for street use.
Sounds like your rear suspension may just need a lube. Worse case scenario is the hydraulics in the shock itself is worn. In which case, replacement is required.
:blink:
https://www.sau.com.au/forums/topic/214440-brake-problems/#findComment-3786978
or your brake pads are almost to the end of its life......might wanna replace them soon.....somtimes they have a little pin which is after certain percentage of wear starts grinding on the rotor....thats a sign to change the pads mate....
https://www.sau.com.au/forums/topic/214440-brake-problems/#findComment-3786990
I agree, but if it goes away when its warm, then it may just be a compound issue. Everyone that I know of (inc myself) who's had this issue, the result has just been pad compound.
In any case, best be safe than sorry. Check your pad thickness. :blink:
Edited by RubyRS4
https://www.sau.com.au/forums/topic/214440-brake-problems/#findComment-3786998
i reackon the best brake pads for street use is the bendix ultimate but there problem is the amount of brake dust it puts out....my car slows down faster then my mates who has slotted rotors and shit pads....i have stock rotors and bendix ultimates...
https://www.sau.com.au/forums/topic/214440-brake-problems/#findComment-3787016
and also...
Do you have stock or aftermarket shocks?
Somethings to check for:
- oil leaks from the shocks, generally from the tops
- loose nut & bolts in the suspension, try tigtening them all up
- worn upper control arm bushes or shock bushes.
Also, before you start forking out $$ for new shocks get a Pedders $14 suspension safety check just to be sure.
https://www.sau.com.au/forums/topic/214440-brake-problems/#findComment-3787199
wats a good place to get those Bendix Ultimates and how much am i looking at?
you'll be looking at around 150? but i don't reccomend them! they can get very noisey even when warm because of the compound! and after a little run in the hills i thought yeah they're good, no brake fade and all but the next day just driving normally and the brakes were juddering! so i had a look at the disk and i lost chunk out of them! like a few mm in little areas so i replaced them and went back to normal bendix! can't say this would happen to you but from a few people only a small number of them haven't had any problems!
https://www.sau.com.au/forums/topic/214440-brake-problems/#findComment-3788364
didnt pay as much for mine happy with braking but i to have that same dame squeel after awhile cant wait to get rid of them but to get rid of the noise i take them out and rub them on the cement and there all good for a couple of months
https://www.sau.com.au/forums/topic/214440-brake-problems/#findComment-3790452
i cant be fecked reading everyones replys so i might have repeated what others may have said,
grinding sound, with the amount of rain the disks could have slight surface rust but wears off after using the brakes a few times. or just the pads are low but doesnt explain the fact that the sound goes away after awhile of driving. never hurts to check though.
the squeaking sound, sounds like the bushings need abit of oiling up.
just going on what happens to me im no guru of cars though.
kye
Edited by Import S13
https://www.sau.com.au/forums/topic/214440-brake-problems/#findComment-3790812
    • well mate, while I hear your pain, turns out I don't feel it this time! Must have been a bastard of a job crammed into the boot The tank was very empty (probably pumped out, not dropped and drained because there were some fumes still) and in very good condition internally. I'm sure he never ran e85 in it I don't know what the hell Nissan's fuel tank engineers were thinking about their clipping system, this hanger was really hard to get moving but came out in the end All looks very good (as I'm starting to hopefully expect) and Matty was right it is an 023 (044) bosch which should be plenty for the injectors and turbo
    • Saturday 8th February 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Thursday 6th February 8pm. Supp Regs: TBC Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. email [email protected] To compete in this event you will require A valid AASA General speed licence Or (Day license is $35.00 via the AASA Website) MA licenses no longer accepted A helmet, long sleeve clothing and it is reccomended a 1KG mounted fire extinguisher (But not Mandatory). Further details within Supp Regs Above. You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Entry Link >> https://www.sauvic.com.au/entry/deca/20250208 Entry List: 1. Martin Sullivan 2.  3.  4.  5.  6.  7.  8.  9. 10.  11. 12.   13. 14 15.  16.  17.  18.  19. 20.  21.  22.  23.  24.  25. 26.    Reserve list 1.  2.
    • I had absolutely no symptoms whatsoever that anything was wrong.... I'm very happy it was all spotto'd and re-bled and re-torqued and aligned though. Will be picking it up tomorrow and undoubtedly be like "Oh, that clunk is gone" "Oh, the car really wants to drive straight" "Oh, that pedal feels better" "Oh, it feels like I've gained 25hp" "Oh, the handbrake works now" It should have been a sign that the new Project Mu shoes had 3mm of pad depth on them out of the box, and the OEM ones from 25 years ago that we took out also had 3mm of pad depth, implying the issue was not, and never was the shoes, but we put that down to it not being adjusted correctly. It wasn't, but it wasn't even adjustable at all given one side was boned and the T Junction of the cables was on a 45 degree angle, the non-working side being the one on the massive angle. Obviously when I had adjusted it and reset it and re-tensioned it I had either got it stuck or something along those lines. Oh well. Live and learn and absolutely could have been catastrophically worse so I'm rationalizing it as a win, kinda. I also got the chance to measure the distance between rear rim and the suspension arm/shocks and found a 30mm rubber block only just doesn't fit there. Which is great to know before ordering wheels, when I assumed 30mm was easy. The man with the Porsche adapters has rims that use 23.9mm of that space, so it's safe to assume I have between 23.9 and 29.9mm of space there to play with on the inside. The wheels looked pretty stupidly pokey with the 20mm spacers on the rear, only for me to find that the studs come out another 12mm and the wheel doesn't actually sit flush with the hub because you're supposed to cut your original studs. The wheels do have cutouts that kinda accomodate it, but not fully. So my 20mm spacer was anywhere between 25mm and 35mm. ~25mm and send it will determine on where the wheels sit with the spacers on. When I put the pads in for the track day I will mess around with spacers (with wheels that do not clear studs properly when mounted to spacers) and do more math, for the last time, for the 7th time.
    • Lucky pick up Best to find these things before something horrible happened to the yoke flange thingies I would hate to think what would happen if it dropped the tailshaft  Hopefully the holes are not flogged out in the yokes and it was just the bolts that got munted  As for the hand brake.....ouch, look like the disc got rather hot, and I assume smokey, I recall when I had a front caliper seize on the Commodore, there was lots of smoke and the disc was glowing cherry red when I was able to eventually stop and have a look, and stopping a big heavy car, going down a big hill with some rather high RPM down shifts and some hand brake action is something that makes you think hard about life
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that one side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
