Originally posted by Baileylsd
I would also like a mod-chip for my ps2
is it bad for them??
like will it not work as well?
no its not bad at all bro, cant harm anything unless it aint installed properly, but i let my customers watch me do it, compare my installations to the technicians in the US that post photos and i guarantee mine's better :D
and it will definitely work and if it doesnt you have the given right to punch me in the temple :D
https://www.sau.com.au/forums/topic/21448--/#findComment-453911
Originally posted by DJ_L3ThAL
darky... my house in tullamarine, and NO im not picking u up :D
err... npz
tullamarine is alright..
do u have a website or something.. so i can check out the stuff you have? coz there are tons of different chips available.. and i dont know which to get :D
https://www.sau.com.au/forums/topic/21448--/#findComment-454023
apache: try and die :D... and depends on the model (SCPH) number form the back of your console and which chip you want, currently im recommending the messiah 2 for people who just want to play copied games and want the bets quality, the magic 3.1 ultra for people who just want to play games and wanna save about $25 and dont mind some cd-r copies not working (they are good if u plan to play dvd-r only.. which is recommended to keep the laser life at its optimal lifespan) and the DMS 3 for people who want what the messiah does + be able to upgrade the chip in the future easily from free downloads from manufacturere's site (www.dms3.com) burn onto a cd-r strick in ps2 and vwala its updated firmware and also multiregion dvd movies and the abiolity to load programs downloaded for the PS2 ie. mp3 players and vcd players etc) when they are released onto the internet in tyhe future (its already happening)
the dms is much more expensive though
darky... as above to decide which chip... and the websites for the 3 chips im offering at the moment are
www.dms3.com
www.messiah2.com
www.china-magic.com
https://www.sau.com.au/forums/topic/21448--/#findComment-454136
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
